Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Error code F 10 during broiling. model #790.78649601
    President:
  • 2,559 Answers
The "F10" error code caused by the runaway temperature.
The first thing to check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Posted on Aug 01, 2010
3 Suggested Answers
milten1
  • 1304 Answers
SOURCE: model 790, burners ignite, but broil or bake does
up is on
Posted on Oct 05, 2009
  • 5603 Answers
SOURCE: Kenmore model 790-96614407 oven stopped heating
Check that you have not lost one side of the 240 volt line at the receptacle. This would be MOST noticeable on the oven but would also reduce the cooktop.
Beyond that, the thermostat and oven timer are suspect.
Inadvertently setting a delayed start of the oven could cause it of course, but that would be obvious.
Posted on Oct 27, 2009
Have a Kenmore electric range model 790 oven seems to be stuck on broil give code for with alarm.
Sounds like you may have a stuck relay. Unplug the unit from the outlet and leave unplugged for about 10 mins. Then plug it back in and the control board will reset itself. If you get the error again, the control board will have be replaced.
Jan 16, 2015 | Kenmore Kitchen Ranges
What would be the cause for top heating element to not work on bake but be ok on broil
Because it is a broil element. Only some models on some brands will BOTH heat during preheat ONLY. Otherwise only during broiling.
Aug 13, 2014 | Kenmore Ovens
F-10 error code on stove
What Kind Of Stove? The following is for troubleshooting an F-10 error on a Kenmore stove:
http://www.applianceblog.com/mainforums/threads/34276-F10-Error-when-using-bake-or-self-cleaning-seems-to-work-fine-when-using-broil
Nov 29, 2013 | managemylife.com
Latch signal mismatch error
first ,check the simple .... reset both dials to off position, then reset the time bake and clock on the upper left hand side ,make sure the start stop clocks are reset , turn back on broil ,bake temperature and see if this fixed the problem,...
Aug 05, 2012 | Kenmore Kitchen Ranges
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Feb 07, 2010 | Kenmore Ovens
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Screen displays error code f3e2
This code means "BAKE/BROIL range over temperature"
Problem is in either temperature sensor or the control board. Check the temp sensor and wiring from it to the control board first (connector #3, contacts 8 and 10, violet wires) . At room temperature the temp sensor resistance should be around 1080 Ohms. Also check temp sensor for short to ground. If no problems found with the sensor - replace control board.
OBTW - for the broil problem - check the fuse inline with the broil element (continuity between Conn #2, wire 1, blue and conn #4, wire 3, red). It should read several ohms. Good luck!
Oct 12, 2009 | Whirlpool RF462LXSB Electric Range
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
246 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
