Question about 2wire Wireless-G 802.11g ADSL Gateway
Protect my wireless route - 2wire Wireless-G 802.11g ADSL Gateway
    Guru:
  • 825 Answers
Dear friend you can have a look at my tips so that you can enable security for your wireless router by yourself...
click here to have a look...
Posted on Aug 01, 2010
  • 2wire Master
  • 32,281 Answers
A secure wireless needs the wireless settings configured with encryption and limit the wireless connectivity to your wireless cards in the computers on your wireless network.
To secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
We do not have wireless at&t, do we have a router?
If your high speed internet service box has multiple data outlets (RJ45 connectors) then it provides IP routing or switching; you can connect your LAN devices through the box (DSL?). If it only has a single data connector, then no, you would need to get an external router (wireless is best). These can be found for under $30 that do everything you need. Be sure to password protect your wireless network - see the set-up instructions for whatever router you get.
Feb 17, 2014 | AT&T Computers & Internet
Key for VT4
If you were to Google this and look for a key ,Google will more than likely find one for you.Caution be careful here ,when doing searches like this you are routed to various sites so make sure you have a good virus protection on before you go to these sites.Also look for key codes or key generators and make sure it is for your version ,check your help on the program and it will generally give you the version number as many games have updates and they only apply to a specific version.
Jan 30, 2014 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I secure enabled my wireless route now I can't access it.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 28, 2011 | Linksys Wireless-G WRT54G Router
Can not connect to wireless router just saying unidentified network it says there is full signal but will not connect to internet
Is it your router password protected?
try unplugging the wireless router in the house and holding the reset button on the back to set it back to default settings.
Leave the route open to see if it connects then. else update the drivers for your laptop and also may have to update the firmware for your router. all can be found on the manufactures websites.
Nov 02, 2010 | HP Pavilion dv6000z Notebook
Connot connect printer to wireless router
this may be due to the security password that is enabled in the router... its recommended to use WEP password in router to connect wireless devices...if you use any other encryption type like WPA/WPA2 then change it to WEP and connect it....if it is a belkin router then you need to disable the WiFi protected setup too.......
Apr 18, 2010 | Brother MFC-9840CDW Laser Printer
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Dec 12, 2009 | Acu-Rite Audio Players & Recorders
Internet Intermittent Drop Out
To isolate the problem beter connect your wireless router directly to the modem and configure it, check if you are able to go online properly so that you can figure out the problem if your wireless router is not working properly, try upgrading the latest firmware and reset the router and reconfigure the router and that will fix your problem...
Oct 22, 2008 | Linksys Wireless-G WRT54G Router
Static routing "Advanced Routing" on Linksys WRT55AG
Any reason why they're not both on the same subnet?
Jun 15, 2008 | Linksys WRT55AG Router
Connecting wireless
Based on the category you picked I need to ask if you want to connect a wireless adapter in a computer to the one wireless router you have or do you have such a large area that you need two wireless routers to cover the space. They are two very different issues. Please add a comment to this issue if you really have two routers -- it is a different problem than the one I will describe.
Assuming the picture of the device is right and it is another wireless adapter you need to connect to the router.-- the simple answer is basically the same as the ones before which is probably not helpful now. (Assuming the wireless adapter is installed and the drivers loaded.) Then if you have an secure network (where WEP or WPA was enabled) you probably will need to connect to the specific network using your adapters manufacturer's software or Windows Wireless Zero Configuration where you will probably need to supply a network name (SSID) and the passphrase that was configured inro the router. If you have an unsecured network your adapter may work without configuration. There is one other possible issue -- most routers dynamically assign ip address and other information to the adapters. If your router was not configured to supply all information including DNS addresses we may have some additional configuration to apply to the wireless adapter.
Please respond if these steps are two complex so I can provide additional information. Please provide the manufacturer and model of the wireless router and wireless adapter if that is the case so I can provide more detailed information specific to your hardware.
Jan 04, 2008 | Linksys Wireless-G WGA54G 802.11g/b...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
