FixYa.com
Tags:
Denon DHT500SD System
Newbie Question
By 2Pansy - usenet poster
Hi, I have a Denon DHT500SD AV System connected to a JVC plasma. Just
setting the whole thing up but can't seem to get TV or Video from the VCR.
I've connected the Denon with the plasma by component cable, the TV signal
is coming in to the VCR, then scart to the denon. Have I missed something?
Can get sound from the TV and Video. DVD works great both sound and
pictures.
TIA
Vince
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Hart
Hart - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Unless the denon has upsampling then the output type must match the input.
What I mean is if the video is composite output then you need composite
input on the plasma.
You can't plug s-video for instance into the amp and then expect a component
signal output.
If it is a normal vhs vcr the best output you can expect is composite!
Gary
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
You should be able to route the composite through the Denon, I think - at
least looking at the specs on the Denon site.
-Vin
Solution #3
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
Cheers - set that up now, got TV/VCR through composite directly connected to
the Plasma. DVD comes in by component cable. Problem is as it's connected
directly I can't use the Home Cinema with the TV or VRC - just the crappy
inbuilt speakers on the plasma.
Vince
Solution #4
Not Rated (0)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
You'll need an extra connection of composite video, since that's the only
signal the video will output.
-Vin
Solution #5
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
So you mean if I'm connecting the VCR to the Denon by scart I can't use the
component cable to play back the output? What's the best cable  I can use?
TIA
Vince
Can you Help with these Home Theater Systems problems?
Denon adv-500sd will not play...
Hi I have a DENON ADV-500 SD... Answer This...
DvD wont load discs
Its been fine up to this week... Answer This...
Switching between functions and...
My DHT500SD has suddenly... Answer This...
Denon 500SD
Power light is on but it is... Answer This...
Auto-switch off
Hi, When we switch on the... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
