Dell Dimension 5100. Nothing on the screen when boot up. Screen is fine with other computers. I have now replaced the cmos battery and there is no difference. Could it be the graphics card. How would you test it?
  • 6,487 Answers
Base from the description of your problem this can really be a video card problem, what you can do here first is to power off the computer unplug the video card from the motherboard and then clean the golden pins of it user a eraser then put it back in and power ON the computer and check if that fix the problem, but if still same problem check if your motherboard has a built in video card then if it does unplug the video card from it and use the built to connect your monitor and if it does work the video card is bad but if it didn't work the problem can be the motherboard already. But to further test the video card its better if you connect it to another computer and see if that will work or not because if it work on a different computer the problem is the motherboard.
Posted on Aug 01, 2010
Dell dimension 3100 win xp home will not logon or go to setup/boot screen, only goes staight to black screen saying TYPE SYSTEM PASSWORD AND PRESS [ENTER] but it doesn't let you type anything. Also will...
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Oct 20, 2013 | Dell Dimension Computers & Internet
How to reset cmos in dell e521 dimension computer
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer.. this will reset your cmos
Feb 27, 2013 | Dell Dimension E521 (D10E16) PC Desktop
"Previous attempts at booting this system have
you can see a logo screen at start computer?
if not the graphic chip are bad if you hear the fans to fast. you can try heat it using a heat gun .
you need to cover all using a aluminium sheet and discover the graphic chip. and heat it for 30 seconds. heat it making circular movement.
you can replace the mother board your self , and bought a used board and u will save a lot of money.
ebay have used and warranted parts for computers.
contact me if need more details , or if u have more info about your problem to figure it.
Dec 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My dell 4600 Dimensions was working just fine. The system locked up and I had to power down. When I tried to restart the computer powered up but there was no boot sequence, no beeping nothing. The green...
if you're familiar on how to open the computer tower's cover, we need to open it.
before opening the cover, make sure all cables are disconnected from the back of the computer. and make sure that you drained the remaining power of the system.
after opening the computer tower's cover, try to locate the cmos battery. (it's a silver coin like battery), remove it from your computer. wait atleast 10 minutes before placing it back. then try to turn on the computer again.
to open the cover, here's the link for the diagram:
http://tinyurl.com/9ax7f
for the complete manual of the system:
http://tinyurl.com/aqzp3
Oct 01, 2009 | Dell Dimension 4600 PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Error lights, Multiple beeps, no display.
Replace the CMOS battery and try again.  Maybe reseat the video card....
Nov 21, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Motherboard
One of the greatest factor in intermittent shutdowns is because of heat issues. try to check the fans if they are all spinning. if all fan's are ok then you only need to replace the motherboard. here's a manual that might come in handy http://support.dell.com/support/edocs/systems/dim5100/en/sm/index.htm
Hope this helps.
thanks
Nov 13, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 8300
Here's Dell's page for changing the battery for a Dimension 8300:
http://support.dell.com/support/edocs/systems/dim8300/sm/battery.htm
Nov 01, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
