Question about Rheem Tankless Water Heater Main Remote Control
Are umc 117 interchangable between paloma and rheem?
  • 700 Answers
No, they are made by different company
Posted on Aug 01, 2010
  • Mark Stillman
    Mark Stillman Mar 12, 2015
    I was told by a Paloma rep. that are in fact interchangeable. Rheem is a subsidery of Paloma, as is WaiWeia.
How do i change the temperature range from 140 deg to 180 deg in the UMC-117 controller?
Why would you want to use it at 180' unless your using it for a dishwashing application.
Nov 18, 2014 | Paloma Tankless Water Heater Digital...
How to change from ºF to ºC on the UMC-117?
According to the 2012 manual, 'the LED display only shows F.'
Bottom page 65. Yet the F temperatures are also shown as C in the manual.
http://waterheatertimer.org/pdf/How-to-set-Rheem-tankless-temperature.pdf
You probably have different model, or older model?.?
Older manual (page 15) shows same temperature range with both F and C, but typical of Rheem, the manual is totally vague about settings and say that qualified tech needed to adjust temps beyond factory default range (with no mention of display showing C) ... which is safeguard since the damg product cannot always heat water fast enough to reach higher set points above 120F.
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
Call Rheem 800-432-8373 and give your product serial number and model number located on side of unit, and ask them.
Don't forget to keep the product maintained to avoid common error codes.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2012 | Rheem Tankless Water Heater Main Remote...
The UMC-117 shuts off during water heat up. What
overheat stat first then check fan best of luck
Oct 10, 2009 | Rheem Tankless Hot Water Heater...
My Rheem Pronto model#RTG-74PNV-1 has powered off for some reason unknown, I turned the unit back on and it supplied hot water for approx. 10 minutes before it started flashing a code [C7]on the remote...
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike//jzklipper@aol.com
Oct 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
My rheem umc-117 controller flashes an IL code.
it means that you have lime build up in the heat exchanger and it needs to be flushed out ASAP!!
Jun 27, 2009 | Rheem Tankless Water Heater Main Remote...
Rheem Tankless Water Heater Main Remote Control   Logo
294 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
