Water keeps coming in to tub - Washing Machines
  • fast walker Jun 07, 2008
    washer will fill with water,then start to wash for a few minutes,then stop and put more water in to overflowing.
Water keeps running in &will run over . but the only thing that will work is spin cycle
Posted on Apr 24, 2008
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
The water level selector of my whirlpool white magic-splash washing machine is causing problem..it does not stop the water at the desired level..the water keeps on flowing into the tub and then overflows...
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Mar 09, 2011 | Whirlpool Washing Machines
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 13, 2011 | Bosch Dishwashers
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
Had a LD error and successfully cleared clog in waste water tank. Turned it on and pump worked perfectly to pump out water. Started a new cycle to test everything and things went wrong. First, the tub...
If the water keeps filling with the unit unplugged you have a bad water valve(or low house pressure)
If the unit does stop filling when unplugged you have a plugged pressure hose to the pressure switch or a bad pressure switch. To access you peel back the front emblem to remove a screw in the center. This allows you to raise the top to check the pressure hose. You can also find the end of the hose at the control panel to blow through it, should be clear when tub is empty of water. A hole in the pressure hose would also cause flooding. This hose connects from the bottom of the outer tub to the pressure switch in the console to control the water level in the tub. Unit will not turn on drain pump if it does not sense water in the tub......
good luck......
Apr 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
My washer leaks occasionally from the back
ok i need a lilttle help from you,,,ok,,,open lid..take your hand and put it on the top of the agitator,,push the hole agitator and tub back,,and let it go if the tub stays back and does not come back center by its self,,your counter balance spring broke,,no mattter which way you push that agitator it shoud come back to near center..what could be bad counter balance springs ,,or tub surport springs.if you need help removing and changing please post
Dec 03, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
