Question about Dometic Rooftop RV Air Conditioner
I HAVE A 1983 RAMBLER IMPERIAL THE FRONT AC HAS AN EXTENSION CORD COMING OUT TO PLUG IN TO AN OUTLET SEEMS FUNNY THERE IS A DESIGNATED CIRCUT BREAKER FOR THE FRONT AC AND ONE FOR THE REAR . THE REAR WORKS FINE BUT WHEN I UN DO THE EXTENSION CORD AND WIRE IT BACK I GET NOTHING. NOW THE THING I DONT UNDERSTAND IS THAT THE WIRE AT THE AC HAS WHITE COATING BUT THE WIRE PLUGGED IN TO THE BREAKER SO THERE MUST BE A JUNCTION SOME WHER THAT CHANGES THEM FROM WHITE TO BLACK OR COULD THE CIRCUT BE DEAD
  • 11,800 Answers
I'm assuming that the color of the wire is black, not that it has overheated so much it has charred. In that case yes, there's a change in the wire. Follow it and find the junction, it's most likely corroded.
But if the junction is fine then the problem is surely in the AC unit, it's dead. The only way to find out what killed it is to dismantle it and test the components. This should be done by someone who has worked before on these units, preferably by a pro. You will definitely need one to refill it, if this is the problem.
Posted on Aug 01, 2010
How do I charge the Fatmax 450 Amp by Stanley
It should come with a DC or AC charging plug. All you have to do is plug it into either the 12v socket on your car, or your AC wall outlet, depending on which plug(s) you have.
Feb 11, 2014 | Vehicle Parts & Accessories
Circut board trips electricty board
Treadmills are machines with a considerable pull of electricity. Make sure you are operating on a dedicated circuit.
Most users have the machine plugged into a spare bedroom outlet ehich is either not dedicate (power source spread out to more then one outlet) or is a GFI outlet (Ground Fault Indicator).
These outlets are used so homeowners do not overload an outlet in an area where a resident will sleep and be in danger of a fore or death.
Usually in the first few pages of your owners manual it will give you the requirements for your machine.
You can run an extension cord to another room with a dedicated outlet, but the extension cord does not transmit all the power coming out of the outlet and will eventually lead to other issues, usually electrical issues within the machine.
You can use a multimeter to see what else could be the issue with your outlet, but will want to consider having an electrician put in a dedicated outlet.
Jan 05, 2013 | Proform 400 CT Treadmill - Treadmills
Need to know how to place extension cords for outdoor ice lights on roof edge of house
Hello, you can use a terminal strip power surge outlets. It will have many outlets on it that then go into one cord that will plug into the outdoor outlet.
Dec 06, 2011 | Heating & Cooling
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
Compressor will not start without tripping breaker?
Circut breakers trip due to a short circut or an overload. In this case the likely cause is an overload. If your compressor is drawing more amperage than the breaker is designed to allow, the breaker trips for safety. Possible solutions. Try using a different outlet with fewer appliances or tools on that circut. If the outlet you are using is on a circut that also has lighting, appliances etc, each item is drawing amps, the addition of the compressor to the circut is pushing the amp limit over the top. You can also try a heavier duty extension cord. If you are using an extension that is rated too low for the required amperage your breaker will trip. If you are not using an extiension cord you may need to talk to an electrician about adding another circut to service your tool and garage needs.
Another possiblity is that your service is not upgraded enough. If you have a 60amp service for the house you might want to talk to an electrician about upgrading to 100amp or more.
Jan 04, 2011 | Garden
When i operate the switch on my karcher pressure washer the power wash does not operate.
But water comes out the end right? just under hose pressure only I bet. I have one of these units and every time I think it has gone bad I manage to find the problem. This unit not only has the switch on the front that needs to be on but it also has a safety switch on the plug where it plugs into a wall or extension cord. The last time I thought mine had gone bad it had actually blown the fuse. the unit was plugged into an outside outlet via extension cord. It just so happens that that is an GFCI outlet. I think the wife got water on the extension cord and that caused it to blow. So check:
The power switch on the front The safety switch on the cord, The outlet it is plugged into
Usually, for us, it is the button on the cord when it is plugged into an extension cord it always gets the test button bumped which shuts it down.
Aug 22, 2010 | Karcher 1750 psi Electric Pressure Washer
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Air conditioner constantly shuts off
Are you saying that you have plugged the aircon into an extension lead then into a socket in the wall and that the smoke was coming from the extension lead part. If so I would suggest checking all your plug in connections and chenge the extension lead. A quick way to check the compressor is a cause is to put the aircon to fan only and see if it fails to trip out the circuit breaker, then put it back onto cooling and see if it trips (if it does on cooling then its a good possibility). Most aircons have a three to five minute time delay for starting the compressor to protect against power fluctuations (ie power cuts). Hope this s of some help.
Sep 11, 2007 | Frigidaire FAC107P1A Wall/Window Air...
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
