Question about Marshall 15 Watt Guitar Amp
Why dose my guitar amp make a high pitch sound when i turn it on
  • 3 Answers
If you have an instrument plugged into the amp, then you need to turn down the volume of the amp before turning on the amp. Otherwise you risk permanent damage to your speaker. Also, the instrument cord may be defective. The hot and ground wires may be shorted together. You need an ohm meter to test your cord. With the cord unplugged and detached, put the positive (red) lead of the ohm meter on the tip of the plug and the negative (black) lead on the sleeve of the plug. You should not have any reading at all. If you get a reading then you have a bad cord with a short.
Posted on Aug 01, 2010
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
Marshall amp troubleshooting
Does anything happen while you turn the knobs on the amp?
I had a similar problem with a yamaha amp. It turned out a couple of knobs went bad. Soldered new pots and it works fine for me now.
Aug 21, 2014 | Marshall Amplification Music
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
6 th string 14-18 th fret buzzing coming out of the back of the amp reverb resonance presence all turned down brought it back where I got it they said it was all good
The problem MIGHT be with the guitar and this amp may be capable of presenting the sound from the guitar. Put a "fake fret" on the guitar... a piece of coathanger wire laid by the offending fret that will slightly raise the string for a test. Does it still buzz with the strings slightly higher, but at same tone... Note you might have to tune the strings SLIGHTLY with this fake fret to get on exactly the same pitch as using the normal fret... If the amp still buzzes with teh strings in no way creating the buzz, the problem is likely something in the cabinetry or chassis that is resonating at that pitch.
Apr 22, 2011 | Marshall Amplification Marshall MA100C MA...
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
HRD Issues...
Try this article first for some ideas. http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165.
Aug 02, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Marshall 15 Watt Guitar Amp Logo
263 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
