Printer keeps on printing same items over & over.
  • 39 Answers
Roller problem pls take it service center or manually clean.
Posted on Aug 01, 2010
How do I clean Print heads
it is one of the very sensitive part in printers so don't touch the printer head nozzels if you want to clean printer head go to tools or settings and go to clean printer head option it is the only way for clening ph safelly option.
Jun 28, 2014 | Canon PIXMA MX340 Wireless Office...
I cant figure out how to cancel print jobs on my printer. Its a brother MFC 210C MFC-420CN Its been out of ink for awhile and now all of these documents are keep printing because we put ink in. I cant get...
If you are using xp click on start , then control panel, then printers and fax, double click and a small window will open showing all of your print jobs. Click on the farthest left item (on mine it says printers) then it comes with an option to cancel all print jobs, click that. I hope this helps. If that first item does not show it click on all of the options at the top till you find the one that says cancel all print jobs.
Feb 23, 2013 | Brother MFC 210C All-In-One InkJet Printer
What is a 50.2 fuzer on a printer
Your laser printer has a fuser on it, this device is used to fuse the toner to the paper. This is a consumable item and does need replacing. The error you are getting is requesting you to replace the fuse. Below is a list from Amazon of available fusers online:
http://www.amazon.com/s/?ie=UTF8&keywords=2840+fuser&tag=googhydr-20&index=aps&hvadid=3997274965&hvpos=1t2&hvexid=&hvnetw=g&hvrand=17470625861140096160&hvpone=&hvptwo=&hvqmt=b&ref=pd_sl_47sd1z0h1s_b
Hope this helps
Mar 26, 2012 | HP LaserJet 2840 Printer
My Dell V510 printer will not print. I have checked the cables, I have checked the ink cartridges, I have unplugged the power supply, I have re-started the computer and nothing helps. Items in the print...
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Can you copy a document under the glass? B&W and color?
What is the correct model of the printer? V505 or V515? Dell does not have a V510.
You can try reinstalling the printer using the instructions located at...
Dell V505 & V505w All-In-One (PRODUCT) RED™ Printer owners thread (W7)
Dell V515w Wireless All In One Printer - (RED) owners thread
Virus programs and firewalls will block communications.
Rick
Apr 19, 2011 | Dell AllinOne Multifunctional (v515w)...
After hitting print button,dialog box comes up printing, but there is nothing printing. Per control panel Printers & faxes everything is ok shows D2600 printer ready, per box item in que is printing
Hi there please try these.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 03, 2011 | HP Color LaserJet 2600n Printer
I got error 6A00. model mp830
Hello i hope u 'll be fine.... thanks for using fixya.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon PIXMA MP830 All-In-One InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The printer won't stop printing, nor will it print the item I selected to print; it just  keeps spooling and spitting out paper.  HELP!!
hi this sounds like you are using the wrong driver for the printer, does it just spit out gobbeldy gook on the paper? if so this is the reason, un-install the printer driver you have currently for this printer and go to
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=uk&dlc=en&sw_lang=&product=3418705#N644
here you will find the correct driver for your printer i have chose the page allready, i dont know what OS you are using, but i chose the xp drivers, if incorrect, just click home page for hp and do it again till you get your OS drivers...hope this helps
May 29, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Canon pixma ip 3000 will not exit the error mode. every time i try to rest it it retunrs, any ideas?
Try turning it off at the mains, it should re set the printer.
Also you can if you have any print jobs in the printer que delete them, you can find that by going to your system tray, normaly if there are items waiting to be printed your printer should be residing there, right click it & choose your printer, from within the screens that are open you should see print jobs in que, select them & delete them
Nov 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Microline 320 Turbo Print Quality Settings
You need to set it in Menu Mode -
Press MODE - the SEL light will go out. The menu light goes on. Press Group and the first line of the menu prints.
Gropu of related items keep pressing group until you see the print mode menu printed - once on the line press SET - keep until the printer prints the setting you want.
After you are finished press MODE to save the changes
Jun 19, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
No response from printer
restart the print spooler service from "services.msc"..also check if your printer works in safe mode or not,if it prints there you must try stopping firewall settings & then try to print..
also delete the pending items to print from the list first...
it it helps,rate my suggestion..
Apr 29, 2009 | Canon PIXMA MP510 All-In-One InkJet...
24 people viewed this question
jasbo
jasbo
