Question about Jet 3 Ultra Power Chair
Can not get power to stay. when you power it up the lights go back and fourth a couple of times then it shuts off. we have 24.3 vdc to controll board.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hi im disabled myself.visit: shoprider.com & download troubleshooter guide for Power Wheelchair,as a PDF File,download it,or do it through Adobe Reader,then you can print n save for future.Hope i was of help Colin.
Posted on Aug 02, 2010
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Riso HC5500 S01-204 error
  • Code: 001 S96
  • Description:Power supply remote signal not connected The control signal cable for the ON/OFF control of the 24/38-VDC output is disconnected. The signal wire grounded inside the power supply unit has been pulled up by the IP PCB to detect the level.
  • Code: 003 S97
  • Description:38-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 38-VDC resistance inside the power supply unit. The detection level is approximately 18 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
  • Code: 004 S97
  • Description:24-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 24-VDC resistance inside the power supply unit. The detection level is approximately 11 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
  • Code: 006 S97
  • Description:3.3-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 3.3-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
  • Code: 007 S97
  • Description:1.8-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 1.8-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
  • Code: 008 S96
  • Description:Control panel not connected The absence of the control panel unit to be connected to the MC PCB is detected. Since this configuration lacks this panel, this error indication will not be issued under normal operating circumstances.
  • Code: 009 S96
  • Description:Print counter not connected The absence of a print counter is detected.
  • Code: 011 S96
  • Description:CIS PCB not connected The connection of the CIS PCB cannot be confirmed.
HP Printer Support Phone Number 1 850 610 1013 HP Support Assistant
Dec 11, 2013 | Riso Office Equipment & Supplies
Service problem and power problem lights stay on all the time-----i have to silence pizo onboard sounder in unit-------24 volt batt are bad------system is on a dedicated power back up ----i do not need the...
This is an integral part of a commercial fire alarm system. Replace or hook up good batteries and that will correct your problem. Their is no way to bypass this trouble feature
Aug 22, 2011 | FireLite MS-4 Four Zone Control Panel...
I am trying to troubleshoot whether or not my ultra x2 connect 550 watt power supply is bad. When you press the power button on the computer, the light flashes and then noth9ing else happens. The light...
Well here is a way to check your power supply, on your hard drive connector using your volt meter and measuring from ground. this would be using one of two middle connectors it should measure +5 VDC on the red wire and + 12 VDC on the yellow wire. If these voltages are good then we got to see if the power supply is producing the -12VDC voltage. This voltage is ussed by the syustemboard on pin 14 of a 24 pin power supply. I would recommend not having your system board plugged in while measuring these votlages, but the power supply may need a load, I would plug in the cdrom.. Below are a couple of picture to explain this and a link to a website that has this documented.
http://www.playtool.com/pages/psuconnectors/connectors.html
dfish26_1.jpg The 24 pin main power connector was added in ATX12V 2.0 to provide extra power needed by PCI Express slots. The older 20 pin main power cable only has one 12 volt line. The new 24 pin connector added one line apiece for ground, 3.3, 5, and 12 volts. The extra pins made the auxiliary power cable unnecessary so most ATX12V 2.x power supplies don't have them. The 24 pin connector is polarized so it can only be plugged in pointing in the correct direction.
Pinout Pins 1 through 12 Pins 13 through 24 Description Wire color Pin number Pin number Wire color Description +3.3 volts orange 1 13 orange +3.3 volts +3.3 volts orange 2 14 blue -12 volts ground black 3 15 black ground +5 volts red 4 16 green PS_ON# ground black 5 17 black ground +5 volts red 6 18 black ground ground black 7 19 black ground PWR_OK gray 8 20 white -5 volts (optional) VSB +5 volts purple 9 21 red +5 volts +12 volts yellow 10 22 red +5 volts +12 volts yellow 11 23 red +5 volts +3.3 volts orange 12 24 black ground
Good Luck I hope this helps.
Nov 19, 2010 | PSA Ultra X2 Connect (ULT31851) 550-Watt...
Tv goes black but you can hear the sound
You need to find out if you do have 24vdc output in the power supply to feed the back light inverter board first to find out if the problem is in the power supply or the inverter board, if you do have 24vdc, then you need to check the inverter board to see if the 24 vdc reaches the inverter board, also check the fuses on the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Insignia+IS-LCDTV32+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 12, 2010 | Insignia IS-LCDTV32 32 in. Television
Just as the others,stays on for a couple secs then go blank. If I power down and back on i ts on for a couple sec. Checked voltage on supply its 12.3 vdc
Point a flashlight at the screen when it shuts down and see if an image is still there. If so, it may be the backlight inverter. You can try to get the part, but most shops would charge you more than a replacement.
To verify, before you pitch it, try it with another monitor and see if the same thing occurs. Ran into a case where something downloaded reset the power-saving settings for the backlight.
Jan 08, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
Power on problem.
What do you mean the power supply has been repaired and outputs 24 vdc and 12 vdc?
Jan 14, 2008 | Protron PLTV-32 Television
Jet 3 Ultra Power Chair Logo
101 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
