Our SONY UP-DR150 has a red alarm light on the front panel that turns on and it says door open even when it is closed.
  • xox_nelli Aug 01, 2010
    Make: Sony
    Model: UP-DR150
    The red alarm light located on the front panel is on and it says the door is open even when it is not. We have tried to restart the printer and computer, and make sure that everything is in the right place (the ribbon and paper).
    President:
  • 2,559 Answers
The door switch has broken off or went bad,you should be able to look and determine if it has broken off or not.
Posted on Aug 01, 2010
  • Randy Hough
    Randy Hough Aug 11, 2010
    Hope that you have resolved this printer issue, If not please post back to the comment section.
    Genius:
  • 1,478 Answers
Reset the printer:
1. Verify that the printer is powered on.
2. Press and hold down the Report Page button.
3. While holding down the Report Page button, press the Cancel button three times.
4. Release the Report Page button.
Take care.
    Our printer does not have those buttons...
    The only buttons it has are:
    -Menu
    -Exec
    -Call
    -Print shop
    It is not under menu, it only says the current count of prints.
  • Jimoh Adeleke Muyideen Aug 01, 2010
    Kindly check all the trays , it can happen if any paper has got
    stuck , kindly turn the printer upside down and shake lightly do this
    after removing the cartridge and power cable.
Tip
HOW TO TURN OFF THE TRUNK OPEN ALARM
The 2012 Camry's trunk lid has a 'trunk open' alarm that shows up on the instrument panel as 'door open' red icon. It also turns on the door open beeping sound so long as the trunk lid is open. This is normal and is usually not a problem..
However, if you should need to carry a large item in the trunk and can't close the lid, be prepared to listen to the incessant door open sound with no means to turn it off!!
The trunk lid alarm 'switch' is operated by the trunk latch when you open or close the lid. By manually operating the latch to it's closed position, you can temporarily silence the alarm.
Using a small screwdriver, you can easily press the actuator and turn the alarm off.
Picture 1: trunk lid latch in the OPEN (Alarm ON) position.
**WARNING**
YOU MUST RETURN THE ACTUATOR TO THE OPEN POSITION (ABOVE)
(ALARM ON) BEFORE YOU CLOSE THE LID. FAILURE TO DO SO MAY DAMAGE THE LATCHING MECHANISM
**WARNING**
DO THIS WITH THE TRUNK OPEN LEVER OR WITH THE REMOTE TRUNK OPEN BUTTON.
Picture 2: trunk lid latch in the CLOSED (Alarm OFF) position.
IF YOU TRY TO CLOSE THE LID WITH THE LATCH IN THIS POSITION YOU MAY DAMAGE OR BREAK THE LATCHING MECHANISM
on Sep 17, 2015 | Toyota Camry Cars & Trucks
Sony KDS-60A3000 turns off by itself and red light flashes 3 times
the flashing light is more than likely the fault code. but those can be wrong bet even money that the door has a sensor to know if its open and the the bi-metallic switch is on the fritz look around the door see of the is a small pressure actuated switch the opens and closes with the door if so all else checks out 85 % chance that will be you problem
Dec 02, 2013 | Televison & Video
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
Alarm sounds when you open the drivers door...
Most likely a bad ground switch in the head light switch.
Jan 24, 2010 | 2002 Chrysler PT Cruiser
2001 olds silhouette non functioning alarm
red light? this is a factory alarm?? Is GM on the key fob? factory alarms dont have "motion sensors" and very few aftermarket alarms do. roll down the window and set the alarm, now open the door and see if it lights off.
Oct 18, 2009 | 2001 Oldsmobile Silhouette
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
2003 Volkswagen Jetta Door Ajar Light wont turn off and car alarm
it is your door switch.you need to replace it.since the door is open as far as the computer is concerned,it will set off the alarm.
Jun 12, 2009 | 2001 Volkswagen Jetta TDI
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Aug 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
183 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
