Question about Cub Cadet Garden
I changed filter and drained the fluid in the hydastatic trans replaced filter and filled with unvesal trator trans fluid which was said to work since i did that now i dont have steering or forwad or reverse or rear lift tried to bleed possible air from steering and still nothing seems to work what else can i do
  • 11,800 Answers
You must bleed it way more, starting with the hydraulic pump - apparently it's not functioning because oil hasn't reach it.
You must do that in the exact sequence and with the exact procedures specified in the service manual for your exact model, otherwise it will simply not work - hydraulic transmissions are very delicate and fiddly and should be serviced only when the hydraulic oil shows sighs of decay. Beware, this isn't something the average customer should do, it's a job for the dealer.
Posted on Aug 01, 2010
How do you change the transmssion fluid on a 2004 isuzu ascender
raise vehicle evenly undo pan bolts on trans (get correct fluid from auto store and service kit before) let drain and remove old filter (making sure drain tray is big enough to hold over 15 litres of trans fluid ) clean every thing spotlessly leavin no trace of lint or contamination in or on pan or trans . replace new filter and pan gasket , fill to the desired manufactures requirements. run thru all gears and check level if possible for correct level , if not possible what the manufactures requirements are. hope that works out well for you
Sep 04, 2014 | 2004 Isuzu Ascender
A few months ago I changed the trans mission fluid and filter truck worked good. Three weeks ago I changed the fuel pump and egr valve, today I was driving down the road and the truck went out of gear, I...
Are you certain you didn't over fill ? There is a difference in quantity of fluid needed on a filter /fluid change and a complete flush of system including the converter . Some will give you a total amount of fluid needed axed on a complete system flush including converter and if you add that amount to your trans and all you did was drain the pan and replace the filter and replaced the pan then filled to the prior mentioned amount you will be drastically over filled. That will cause as many if not more problems as being low or empty on fluid.
Aug 09, 2013 | Cars & Trucks
How to change a transmission screen on a 05' ford
The filter is not replaced unless an overhaul of the trans-axle is needed, It involves the removal of the trans-axle and partial disassembly to accomplish the filter replacement. That is only if trans failure is suspected, and diagnosis requires removal and inspection of the filter. The filter removal and replacement is procedure 42 out of 72 in the disassembly manual and 12 different Ford specific SST's (Special Service Tools) are needed. I did however, include the procedure for the normal drain and fill service performed at the dealer.
I hope this info helps!
subyguru
Transmission Fluid Drain and Refill
Specifications161937054
Material
Draining
  1. With the vehicle in NEUTRAL position it on a hoist.
115061162
  1. NOTE: If an internal problem is suspected, drain the fluid through a paper filter. A small amount of metal or friction particles may be found from normal wear. If an excessive amount of metal or friction material is present the transaxle will need to be overhauled.
Remove the transaxle drain plug.
Refill
115061164
  1. Using a small amount of pipe sealant on the threads, install the transaxle drain plug.
    • Tighten to 27 Nm (20 ft. lbs.) .
  1. Fill the transaxle with clean automatic transmission fluid.
  2. Start the engine and run through all the gears and check fluid level.
Dec 18, 2011 | 2005 Ford Escape
How to refill brake fluid in 1995 hyundai elantra?
Manual trans: remove the filler plug (high up on the drivers side of the car... looking at it from underneath) stick a thin hose attached to a fluid pump into the trans until it touches the bottom then **** the old fluid out. then fill to the bottom of the fill plug hole with the correct oil (75W-80W gear oil), replace the filler plug.
Automatic trans: remove the drain plug on the pan, drain into a container, remove pan, clean or replace filter/screen, replace pan, fill with correct oil (not common Dexron II or III -- Hyundai ATF SP-II or Chrsyler spec 7176).
Sep 09, 2010 | Hyundai Elantra Cars & Trucks
How much trans fluid capacity in the manual 5 speed dodge stealth
never change filter as i dont think it exsists. The fill should be located on the transmission up from the drain. You fill untill fluid pours out and stops then replace plug. Car must be level.
Apr 19, 2010 | Dodge Stealth Cars & Trucks
Changing trans oil and filter on 2005 explorer
Theres a drain plug on the bottom of the pan, you need to get a clean pan and drain the old fluid in the bucket so u can measure how much fluid to put back in the transmission. Remove the pan bolts and the pan and replace the filter, reinstall the transmission pan . In the center of your drain plug theres a star head plug remove it, this is your fill hole for the fluid. You will need a fluid exchanger for the fill procedure if you dont have one you can get one at Napa. With the truck running at operating temperature fill the exchanger with fluid and insert the rubber tube into the fill hole in the drain plug. Slowly fill the transmission with the same amount of the old fluid that you drained out. Reinstall the fill plug and test drive the vehicle and check for leaks.
Jan 22, 2010 | 2005 Ford Explorer
How to change transmission fluid
There are 2 plugs in the trans. pan. The one that is lower or closest to center is the drain plug. The upper plug is the fill plug. Remove the drain plug to drain the fluid. I would recommend if the vehicle has over 60,000 mile that you also remove the trans. pan and replace the filter. You will need a pump of somekind to pump the fluid into the fill plug hole. Reinstall the drain plug make sure you replace the seals on both plugs.Remove the fill plug and pump f;uid in untill it comes out. With the vehicle level run the vehicle until warm shifting through foward and reverse several times. Trans fluid is full when fluid just begins to trickle out of the fill plug hole when hot. Reinstall fill plug with new seal.
Oct 12, 2009 | 1998 Isuzu Rodeo
Will be hard to change a transmission filter in a 89 buick park avenue?
the trans filter is internal.raise & support vehicle.fluid is drained by removing transmission pan.this can get messy.trans pan gasket & filter are usually sold as a set.fill W/new fluid through dipstick tube.note that trans will not need as much fluid as is listed in specifications--torque converter will not drain.if you change your own oil;this is the next step.
Sep 21, 2009 | 1989 Buick Electra
How do i change trans fluid in 1993 for econoline.
You must remove the transmission pan to change the fluid, there is no drain plug.
Aug 26, 2009 | 1993 Ford Econoline
Transmission fluid/filter change in 2000 Honda Odyssey
I would not recommend using Dexron III. Honda Odysseys are prone to transmission problems. A drain and fill with Genuine Honda Fluid is Recommended. The drain plug can be removed with a 3/8 ratchet at the bottom of the trans. The fill hole is at the top of the trans. You remove it with a socket on a long extension. The capacity is close to 3 quarts
Apr 07, 2009 | 2000 Honda Odyssey
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
