Question about SGI Silicon Graphics Silicon Graphics Onyx2 PC Desktop
NEED TO PUT IP ADDRESS ON ONYX2 ON COMPUTER - SGI Silicon Graphics Silicon Graphics Onyx2 PC Desktop
  • 4,281 Answers
Go to start menu ->run or press windows key +R key so you can see run type in "ncpa.cpl" without "" then press enter then you can see local area connection right click on it then click on property then click on tcp ip property then you can set ip address,subnet mask and gateway and dns. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 01, 2010
Where can I find the IP address on the XBox 360
If you know your router's IP address, then here are the steps:
If you still need assistance, feel free to post additional questions.
To set your Xbox 360 console's IP settings
  1. On your console, press the Guide button on your controller, go to Settings, and select System Settings.
  2. Select Network Settings.
  3. Select WiredNetwork or the name of your wireless network, if you are prompted to do so.
  4. Select Configure Network.
  5. On the Basic Settings tab, select IP Settings.
  6. Select Manual.
  7. Select IP Address.
  8. Enter the unique IP address that you made up, and then select Done.
  9. Select Subnet Mask, enter your computer's subnet mask, and then select Done.
  10. Select Gateway, enter your computer's default gateway, and then select Done.
  11. Select Done.
Apr 10, 2012 | Microsoft Xbox 360 Console System
I need the Konica Minolta Di470 ip address to connect the pc to print documents etc.
The ip address is provided by your it department if you do not have an it department then you can select an ip address that is not being uesd example 192.168.1.200 this lus the sub net mask standard sub net mask 255.255.255.0 needs to be put in the network section of the machine then you can go to the c: prompt on your computer type in ping then the ip address you put into the machine you should get 4 replys and no drops then you will also need to load the print driver for the machine onto your computer
Jan 11, 2011 | Konica Minolta Di1610 Copier
Is the the router No 191.168..1.1
Hi Thanks for your question
Default routers IP would be 192.168.1.1 although this may vary! To be sure you choose the right one you need to do this. Press
Start--->Run--->
In run box put "cmd" (without the quotation marks) This should open you a command prompt Put "ipconfig" and press enter. You will be showed your current ip configuration. The address that your after is the "default gateway" this will be your router IP. For more about routers and accessing settings please read this http://www.fixya.com/support/r4695161-change_wireless_network_password_forgott.
I hope this helps Good luck
May 11, 2010 | Linksys WAG200G Router
IP Address problem
how do you know what the ip address is? you need to log into your router and find the device that says nfusion and that will be the ip try going there.
it wont just be YOUR ip address
Aug 03, 2009 | Televison & Video
I am using Belkin F5D7632ak4A. My problem is that:
In doing a port forwarding, you actually need to assign a manual address on the computer where you are using the service port for the computer not to change the IP address. If your private address on the network is 192.168.1.XX then you may assign on your computer 192.168.1.2-99 any of the address there. Also you may need to know the DNS you are using on the router which you can find on the status tab of the router.
To assign an IP address, if your computer is wired then right click on the wireless connection and select properties, if it is a wireless computer right click on the wireless connection and select properties.
After you have selected the said properties> look for Internet Protocol TCP/IP then select properties.
Then click on USE THE FOLLOWING IP ADDRESS and USE THE FOLLOWING DNS server as well.
then from there you can put in the set of address you have for ex.
IP address 192.168.1.10
subnet mask 255.255.255.0
Default gateway 192.168.1.1
DNS
preferred DNS 66.28.87.105
alternate DNS 66.28.87.104
Note: these are just example. after you have done assigning an IP address then you may do the port forwarding again. change the IP address on the port forwarding tab to the IP address you have assigned. Then don't forget to save the settings.
Jul 17, 2009 | Belkin (F5D7230-4) Router (587009)
Image runner 2230- computer not recognizing IP adress for scanner
you must be shore that the cable between the copier and the co mputer is cross cabel and connected if there is a switch put normal cable
and then be shore that the diference between the two ip.s is smal as the computer ip 192.168.1.20
and the copier ip 192.168.1.30
Apr 28, 2009 | Canon IMAGERUNNER 2230 Copier
Failed ip address
your ip address should be activated by your isp
and then manually put it in the smart phone
Mar 04, 2009 | Microsoft Xbox 360 Console
I can't find the IP Address on my ARRIS Router!
the ip address should be given automatically by the router but since it is asking,
in your computer go to start,run,type in cmd and hit enterm
it should open a black box in that box type in ipconfig and hit enter,
it should give u a list of result,search the one which says ip address,
if the ip address of ur computer is 192.168.1.2,then the ip address for your xbox should be 192.168.1.7,
if the ip address is different than the example i gave you just make sure that the difference between the last numbers should be 5 atleast....let me kno the ip address of your computer and i can tell what ip address u need
for the xbox...........
Jan 31, 2009 | Black Box IP Address Translator With...
Ip address
You can try this site http://www.ip-details.com/ for getting the ip-address.
Jul 31, 2008 | Computers & Internet
Networking problem
For malvic: doubt you still need this but you don't give your pc an address with this router. Make sure in your tcp/ip properties you have checked obtain ip address automatically.
Feb 19, 2008 | D-Link Express EtherNetwork DI-604 Router
SGI Silicon Graphics Silicon Graphics Onyx2 PC Desktop Logo
35 people viewed this question
Top SGI Silicon Graphics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SGI Silicon Graphics Computer and Internet Expert? Answer questions, earn points and help others
