Question about Midland 1001Z 40-Channels Base CB Radio
Hy, I've installed my midland 1001z on my car with a truth glass midland antenna, I live in DR once I turn on the radio it just does not receive anything, it shows that i can transmit but I don't receive anything can this be the crystal from the radio that it's not compatible for this country or something else? I'll really want to know because I've try everything and nothing seen to work. Thanks.
  • 29 Answers
Hi
May I ask if you checked the swr on the antenna or may be try another type of antenna.
Ray
Posted on Aug 23, 2010
Midland CB radio model 1000/1001Z short distance transmitting and receiving,approximately 1/2 mile only
There can be a number of problems causing this. The most likely cause is something is wrong in one or both of the antenna lines.
Another problem could be that one of the radios has a broken connection at the antenna jack on the rear. I am sure that you will find the problem with one of them, not both, if you have the SWR and output power checked on both radios.
You did not say if you have tried contacting others from both radios. The one that can't talk to others has the problem.
Feb 20, 2017 | Midland Radio Communications
How do you turn up the power on a midland 1001z
You can't "turn it up". You may be able to carefully compress or spread the coil windings near the Final Output Transistor (Q 14 a 2SC 2078) to get a bit more out of it but it isn't a real "Big Time" CB like the Cobra 29's. Sorry.
Feb 13, 2014 | Midland 1001Z 40-Channels Base CB Radio
I cant be heard when i speak through my midland 1001z cb radio?
hello have you checked the swr on the antenna have you checked the output of the radio with a power metre it should be reading 4watts max if yes problem might be the microphone make sure there are no wires shortening in the mic socket entering the radio and check inside the mic aswell
cheers and goodluck
Jun 26, 2010 | Midland 1001Z 40-Channels Base CB Radio
I have a midland 1001z cb radio with a magnetic mount attenna by cobra. When I transmit receivers are getting a lot of squealing. Before I bought the midland i had a radio shack cb which worked find.
is this same antenna as before. you should always check the SWR's to see if set correctly.. other than that. bad grounds, bad microphone can make any radio squeal..
Nov 27, 2009 | Radio Communications
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
Audio playback through speakers
HELLO
This happens because of the close proximity of the CB transmitting antenna to the car stereo antenna. I don't know for sure what country you live in, but if your country's CB system uses AM as a transmission mode it is well known for breakthrough on audio systems etc. In the UK, we have FM on CB frequencies which is less-prone to giving interference.
You could try ferrite rings/clamps on the car stereo antenna coax cable, power cable and also on your loudspeaker cables too. Apart from that - that is all you can do using it mobile!
GOOD LUCK
Sep 02, 2009 | Midland 1001Z 40-Channels Base CB Radio
Is it my CB antenna or something else
First off, Midland makes a fine radio. Make sure your squelch is turned all the way down to receive distant signals (down meaning counter clockwise). The through the glass antennas are not the best thing in the world. I personally use a 102" whip and a 6" spring on a modified mirror mount. It is installed on the tailgate side of the tool box. The TX and RX is amazing. Wilson and K40 make great antennas also.
Jul 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
S it my CB antenna or something else
take a 9 foot wire to the bad radio put the the wire into the center of the ant jack a see if you can hear your buddy glass mount ant are ****.
9 foot whip is best in car/truck 4 foot fiberglass cophased are next 4 foot are next mags are ok but over time and moving around they will mess up you paint
MIdland no sound s/rf dancing
may be u burned yr final transistors...check if yr antenna is well grounded and try just after this to transmit, if the indicator is not stable on the green area when you are in "am" modulation stop to try and bring to the assistance
rgds Stefano
Dec 17, 2008 | Midland 1001Z 40-Channels Base CB Radio
How far can that midland 1001z radio transmit.And recieve.
Running most any regular cb, including this one barefoot (with no kicker), having a good antenna, set up with a good ground plane or a no-goundplane antenna, good coax; basically everything in good working order, you can usually bank on about 4 to 5 miles crisp and clear, and at least 6 to 10 miles fairly clear. Of course the further out you get it will start to fade out.
Some radios do better than others, but those are the general numbers I have seen in my years of experience.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Apr 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
124 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
