Question about SanDisk Sansa e250 MP3 Player
My mp3 how can i fix it when it gos to a black screen and every time i try to hold the power button it turns off
  • Anonymous May 06, 2008
    One Day, I turned my Sansa E250 Off, And When I went to Turn it back on, All i got was the Blue Nav Wheel lightm Nothing Else, Even when plugged in
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Ipod has red x
For now my suggestion is: Again, try to Restore from Disk Mode. If that doesn't work you may need a repair. Do the reset, then after the screen flickers to the gray Apple logo; let go of both buttons and then quickly press and hold the center and play/pause buttons. You should see a black check mark on the iPod screen. Plug it in and restore.
Apr 18, 2012 | Apple iPod Audio Players & Recorders
My ipod touch wont turn on, it shows the little pple symbol on the screen, then flashes white, blacks out, and the apple appears again. I've pressed all the buttons to try to get it to work, but it keeps...
try holding the menu button and the power button for about 20 secs. this will cause it reset, if this method doesn't work, then hold down the menu button, connect it to a PC then hold down the power button, if you have Itunes installed on your computer, it will alert you that it detects an Ipod in recovery mode, basically after that it'll attempt to fix your problem, and it will be able to turn on again.
Jan 18, 2010 | Apple iPod touch
The RCA M4204 MP3 Player does not turn on no matter what...
reset it either on the back or hold down the menu button for like 15 sec.
Jan 15, 2009 | RCA M4204 MP3 Player
Screen is black
you must restart your sandisk sansa. hold in the power button for a few minutes. good luck! please rate! =]
Dec 27, 2008 | SanDisk Sansa e250 MP3 Player
Problem starting
Get the Sansa Recovery Tool from the sandisk website
Jun 28, 2008 | SanDisk Sansa e270 MP3 Player
Sad face on 80 gig cant restart
You can try going into iPod Diagnostics
Just click and hold on the Home and Center button at the same time until the screen turns black, then click and hold on the Center button and the Rewind button (Left button) until something different than a iPod display comes out.
Hope this helps!
Nicholas
Jan 26, 2008 | Apple iPod MA446LL/A MP3 Player
My mp3 player will not turn on, charge, or get detected by the computer. what do i do?
I saw it mentioned somewhere else....hold down the power button for about a minute. It should come back to life. It just worked for me, after I paniced a little, of course!
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
My e260 turns on then goes to sansa screen
tyr holding the power button for 20secs or try taking the battery out or try holding the power button and the play bttuon at the sametimefor 20secs.
Dec 25, 2007 | SanDisk Sansa e260 MP3 Player
Black screen
Sometimes the player crashes with a blank black screen. It looks like it's turned off, but it's actually hung. Try holding down the power button for about 30 seconds, or until the player reboots itself.
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e280 8gb white screen with black spot
It sounds like some data corruption.
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
