Question about Sony Cyber-shot DSC-W35 Digital Camera
My Sony DSC-W230 turns on and lens keep opening and closing, and then it shows "turn power off and on again". how do i fix this ?
  • 3,083 Answers
This sounds like a stuck lens. Here is a good blog about things to try to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The blog is about a lens error, but when the camera lens opens and closes, there is often a problem with the lens.
Also make sure the battery is fully charged, and good. Also make sure the contacts are clean on the battery, and also inside the camera.
If all fails to get it working again, get an estimate on repair first, since the cost can justify just going ahead and buying a new camera.
Good luck, and hope this helps.
Posted on Aug 01, 2010
The eye of the lens won't close anymore and keep saying to turn the power on and off again, what should I do?
You might try removing the battery for a minute or two to reset the camera. You may lose any special settings in the process. After reinstalling the battery, try turning the power on and off again.
Apr 28, 2012 | Sony Cyber-Shot DSC-W570 Digital Camera
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
When I turn my DSC W230 Sony Camera on the lens opens and closes several times then finally closes and I get a message to turn it off and on again, but it just keeps doing the same thing. I have tired...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1
Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
May 12, 2011 | Sony W230 Digital Camera
I have a sony cybershot w-290. I downloaded pictures to my laptop from the memory stick. When I turn it on I get a message to turn it off and back on again. My lens keeps going in and out. I show full...
Sounds like your lens has issues. Probably some debris/sand got into it or maybe it suffered a
Jolt of some sort. Whatever the case maybe you will need to get your Lens serviced.
Sometimes if you use a case the camera may have turned on inside the case and caused
lens damage.
Feb 02, 2011 | Sony Cybershot Dsc-w290 W230 W220
IAM TRYING TO TURN ON MY SONY DSC-W90 CAMERA BUT DOST NOT TURN ON AND LENCE FREQUNLY TRY TO OPEN CLOSE AND I RECEIVED MESSAGE ON LCD DISPLY TRUN THE POWER OFF AND ON AGAIN , EVEN I REMOVED AND FIX BATTRY...
The error message is due to the lens issue. the lens might have stuck due to moisture condensation or dust. It may require service to resolve the issue.
If you wish to resolve it yourself, you may use a soft cloth to clear the dust by manually pulling out the lens part..
If it doen't help, it may require opening the Camera
Jan 22, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Camera lens keeps opening and closing and message says " turn the power off and on again".
I followed the other people's suggestions with the compressed air and shaking the camera. I also, turned the lens a little to the left and the camera works perfectly. Thanks, again for everyones help.
Oct 10, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
When turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Mar 21, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
1,166 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
