Question about Horizon Fitness Merit Fitness 725T Treadmill
The treadmill powers up but the belt will not work
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
The motor controller has failed and will need replaced
Posted on Aug 13, 2010
Tread mill has power but light on indicator panel are frozen and no functionality on panel
Posted on Aug 15, 2010
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
Belt stop working. All lights lit.
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
May 16, 2010 | Nordic Track /proform Treadmill...
I started up my treadmill after a year sabbatical :) to find that it stops abruptly when I increase the speed above 4 and then when I restarted it as soon as I stood on the belt the motor lagged & then...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 28, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Pro-Form XP 550 Troubleshooting
My Proform 550 doess not work the treadmill is not getting any power. Wht might the problem be.
Apr 27, 2009 | Exercise & Fitness
Horizon Fitness Merit Fitness 725T Treadmill Logo
450 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
