Question about Canon Cameras
I put new batteries into the camera and turn it on and the lens zooms way out and I can't get it to zoom back in and take a picture.
  • 4,472 Answers
First off what is the make and model of the camera? How long have you owned it and how long have you been having this problem? Once I have the model information I can assist you further.
Thank you,
Lee
Posted on Aug 01, 2010
  • Shelly Porter Aug 01, 2010
    Canon Power Shot SX120 IS 10x optical zoom and I purchased it in February of this year. I just started having the problem today. What do I do?
  • Lee A.
    Lee A. Aug 01, 2010
    Then the camera is still under warranty and I highly recommend you don't wasting any time having it repaired under the manufacturer warranty. Just follow this link to start the repair process through canon.
    http://www.usa.canon.com/cusa/online_rep...
    If you have any other questions let me know.
    Thank you and good luck,
    Lee
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
LCD screen Black - manual Zoom not working
Hey,
It sounds like you're having the same problem,
Here is a link
http://www.e18error.com/repair.html
It may be usefull,
good luck mate!
Jul 26, 2010 | Canon PowerShot A630 Digital Camera
My Fuji S1500 lens will not go in and out? It reads zoom error
Put a freshly charged battery in the camera. Lay it on its back on a firm smooth surface with a cloth between the camera and the surface. Hold the zoom button in and while holding it in, turn the power on the camera. If the lens moves tun the camera so the lens points down and continue to zoom in and out. That may free some grit or dirt wedging the lens in place. If that doesn't clear the trouble, look closely at the lens and the way it sits in the camera housing. Check to see if the gap around the lens is even. If it is not, gently apply pressure with your hand in the direction of the widest gap. Listen closely for a light snap. If you hear one, the adds are the guid pins snapped back in place and you may now try the zoom. If all this fails there is one more thing to try, but it may result in further damage. if you will probably trash the camera otherwise, try this. Remove the battery. Holding the camera firmly by the edges with one hand with the lens down, slap the camera into your cupped opposite hand several times. Replace the battery and try the zoom. If the zoom works this time, with the lens pointing down, zoom the lens in and out several times to try to let the grit or dirt jamming the lens drop out.
Mar 29, 2010 | Fujitsu Cameras
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
D-535 zoom
try to remove the battery for an hour.. then put it back again.. then charge the battery at least 3hours..
Jun 27, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens Stuck Out/Will Not Go Back In
well u have a problem, and u will need to replace the mainboard. if it´s under warranty send it to the repair centre they will replace mainboard for free
Mar 01, 2007 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
