Question about Relic Moving Color ZR55055 Watch for Men
Hi I just bought a Relic Moving Color Men's Watch ZR55055, and the clock itself is not moving but the background is. They said that it might be just the battery but I'm sure that the time was right at the moment and after sometime it seems that it havent moved from its position before. Is it just a coincidence that the battery is dead or maybe some other circumstances happened.
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
escapement
  • 2334 Answers
SOURCE: Need a new back for my Relic (Susan G. Koman) watch
The only way I can see is to try to contact FOSSIL (Relic are made by Fossil).
You will find Customer Support as well as How to contact etc.
The link is here:
www.fossil.com
If you can't find what you want, send an email to them explaining what exactly you are looking for.
Do not forget to rate, please.
Posted on Jan 04, 2009
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Posted on Jan 26, 2009
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Posted on Feb 10, 2009
Hamilton jazzmaster watch
The large hand is the chronograph (stopwatch) hand and only moves with the stopwatch.
Mar 07, 2012 | Hamilton Laboratories Hamilton Jazzmaster...
How do you set the time on a Relic ZR85049 pocket watch?
the crown in the top of 12 o'clock must be pulled. and turn it to adjust the time.
Jul 23, 2011 | Relic ZR85049 Pocket Watch for Men
Two years ago , I bought Bulova 26e10 men watch and yesterday it stopped moving . I noticed that it was slower than normal watch first of all and then it stopped moving when I let it alone 3 days....
Don't know what battery but a watchmaker will be able to help you for a very reasonable cost. He will also inspect the rest of your watch, case and band. Your watch will likely need the chronograph reset also.
Mar 28, 2011 | Accutron 26E10 Lucerne with Chronograph...
What kind of batery need for relic zr 15490? i don't know because i lose my old batery.
mcdevito75 Here, Your in a spot, Looseing the old battery to your Mens Relic watch, you can look for a small watch repair shop in your area, they may have an idea of the battery number, but will most likely tell you they need the watch to know for sure. You can also try battery 364 or 371 but even I can"t be certain. You can also try online at Contact Relic Watches.com Reic should have a website. You may be left with only 1 choice, have the watch repair shop replace this battery for you, you"d have to buy and try a couple of different batteries and each battery in the store runs about $5.00 each, at the watch shop let the Jeweler figure out the battery number for your watch for 1 price. I think this is your cheapest and best option.
Feb 11, 2011 | Relic Dial ZR15528 Watch for Men
What battery is the replacement? Relic ZR11622
Thank you FixYa.
Look on the back of the watch, or in the manual. If it doesnt say the battery size you will need to take to jeweler to have them measure the compartment to see what battery is needed. Sorry but no other way to know the battery needed.
Best regards. Jewel
Sep 19, 2010 | Relic Wet ZR11657 Watch for Men
Seconds hand stops moving
1st reason. This means your oscillating weight and paired gears are not generating enough power to charge capacitor, thus not be able to move hand properly. 2nd reason. Capacitor can not recharge itself to full power and needs to be replaced. 3 reason. Seconds or chrono wheel has a mechanical fault developed over the time and needs to be cleaned or replaced. Those are 3 reasons why the seconds hand stops moving in Kinetic watch. Which one is right, you will find out only after visiting watch repair shop, because I can not give correct estimate without seeing the watch myself.
Rate me, plz.
Jan 11, 2010 | Seiko Premier KineticĀ® Perpetual Watch for...
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
Relic Moving Color ZR55055 Watch for Men Logo
54 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
