Question about Saeco Incanto Classic Espresso Machine
Is it possible to raise the dispensing temperature
My espresso is not as hot as i would like it be.
  • Julian Scales Sep 10, 2008
    Please advise how one sets the water level to high as I also have too low a dispensing temperature. There is nothign in the manual povided with my machine unfortunately.
Make sure you have the water setting to high and preheat your cups
Posted on Apr 24, 2008
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
Why wont the steamer work
hi,
he pump presses hot water through the grind not steam.
if the coffee is hot and hot water is dispensed, your line are clocked.
descale the machine as directed.
if coffee is cold the heat element is toasted. very unlikely though, since the machine will not dispens coffee, pump running if correct temperature is not reached.
good luck
Aug 08, 2014 | Saeco Royal Professional Espresso Machine
Hot water dispenser does not dispense well
Most likely is the faucet/tap is broken inside and does not lift properly as the handle is raised. You can get a new tap which is easy to replace from your local Bunn distributor.
May 17, 2014 | Bunn DualĀ® (20900.0011)
Reduced flow of hot water through the coffee brewing head and increased noise level from the pump. Both pressure and temperature too low for espresso
Check screen and diffuser for blockage, backwash machine. If you still have the noise problem, when runnig the head, then it is block at the solenoid. For the temperature, it is possible that the one of the thermostat is damaged.
Nov 27, 2009 | Rancilio Silvia Espresso Machine
Water line keeps freezing.....
Probably the easiest possible solution might be to raise the freezer temperature a bit. If the freezer does not have a built-in thermometer that shows the temperature, get one and sit it inside the freezer. Wal-Mart should have these.
The temperature in a freezer should be around zero, plus or minus a few degrees. If the freezer shows a temperature significantly less than zero, you could certainly adjust the temperature control to raise the temperature a bit without causing any problem.
The water line runs outside the freezer for most of its run. However, it must come inside to reach the water dispenser. This short distance is where it would be susceptible to freezing.
Oct 20, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Too much water in espresso, Steam spits water
Hi
Yes it is possible to raise the temperature but it requires taking the top off. Most people are not into removing the top. email me if interested
Apr 17, 2009 | Saeco Vienna SuperAutomatica Coffee...
Please help
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Dec 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
Coffee not hot enough
My coffee machine doesn't get very hot either, I add hot milk to the coffee in order to raise the temperature a bit.
May 17, 2008 | Miele CVA4070 Coffee Maker
Coffe not hot enough
lot of time calcium in boiler = lest heat descale it with descaler not vinegar if our not sure how to descale let me know it would be my pleasure to help you
thanks for using fixya
pierre
Feb 26, 2008 | Spidem Trevi Automatic Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
89 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
