Question about Sony Electronics - Others
I have a 1993 model Sony mega watchman, no power at all, not from AC plug or batteries, what could it be?
  • 3,083 Answers
The on/off switch could be dirty or broken, and will need to be replaced, if bad. You might be able to spray some electrical contact cleaner on it to get it working again, if it's just dirty or oxidized. Other than that, the unit could have another major problem that would require servicing. Oh, the power jack on the watchman could be sprung or bad, not allowing juice to the main board. Good luck and hope this helps.
Posted on Aug 01, 2010
How to fix my samsung galaxy mega 5.8 screen after replacing won't work
As with most modern electronics today, the failure of one component can cascade through other pieces of the system. Replacing the obvious failure often times reveals that more than one piece has been 'fckd'.
Typically, repair is not an economic choice.
Apr 02, 2015 | GMYLE iPhone 5/Samsung galaxy s4/Galaxy...
Power managment
Hi, A Sony VAIO PCWA-A200 is an 802.11b Wireless Access Point Router. Your post "...AC PLUGGED IN AND RUNNING ON BATTERIES...." indicates a laptop issue. To be of better assistance, post the brand/model of your laptop.
Aug 27, 2007 | Sony VAIO (PCWA-A200)
Tip
SAFEGUARD YOUR HOME/BUSINESS WITH HONEYWELL'S WINTER WATCHMAN!
I recently discovered a great device, manufactured by Honeywell which is guaranteed to provide you with peace of mind whenever you are away from your home or business for more than a few hours. The Honeywell Winter Watchman UPC#: 085267870511, is a freeze warning alarm. Winter Watchman turns on a light alerting neighbors of a cold, low temperature condition. The model number is S483B1002 and the cost is in the $25.00 - $30.00 range.
This device plugs into a home outlet and then you plug a lamp into it. Make sure the lamp is on before you plug it into the Winter watchman. I use a lamp with a red globe and place it in the front window. Then I notify all of the helpful neighbors of my warning system so that can call me,or my designee, if they see the red light on. One of the features of the Winter Watchman is the fact that you can set the warning temperature, ten degrees below the setting on the thermostat would be a good setting in that the warning light would activate but your home wouldn't be in danger of an immediate freeze of the water pipes. OTHER modifications you might consider would be:
1. plug a spot light with a red bulb and a flasher unit into the Winter Watchman to get everyone's attention.
2. Use more that one Winter Watchman, perhaps on the other side of the house so that multiple neighbors can be alerted.
on Dec 23, 2009 | Kitchen Appliances - Others
Users manual for sony watchman FD-30A
Google the model number with "manual" or visit the Sony site as they have many available online for free.
Jun 16, 2012 | Televison & Video
PICTURE WILL NOT APPEAR ON SCREEN
First, I would check to see if the AC adaptor is working. If you are on batteries instead, look for corrosion on the battery housing-usually on the springs
May 28, 2010 | Televison & Video
I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
Follow this procedure to troubleshoot if the camcorder will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
Aug 14, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Cannot get picture on my Sony Watchman TV/Radio-just standby flas
May have something to do with the switch to digital tv that occurred back in Feb.
Apr 20, 2009 | Sony Watchman FDL-250T 2.5 in. Handheld...
Will Digital Converter Plug in to 1993 Sony Watchman?
Yes,you can use the audio/video input jack on the TV with a connecting wire (mini-plug on one end,RCA plugs on the other) hook other end to output on converter box.
Jan 29, 2009 | Sony Watchman FDL-250T 2.5 in. Handheld...
Tv reception on handheld Sony Watchman in Feb 2009
The old Watchmans are analog. If plugged into a digital cable/dish system it will scan in UHF and find the working channel than can be conrolled by your digital remote control. As far as taking it out on its own and working off the external antenna...those days will be over. Sony will have to manufacture digital Watchmans.
Jul 07, 2008 | Sony Watchman FDL-22 2.2 in. Television
Electronics - Others Logo
180 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
