I have a siemens waching machine model no wd11640hkbu. few days back when we were running a wash + dry cycle, while it was on the last 5 minutes of the dry cycle, there were loud banging noises and some smoke/ steam starting getting emitted from the loading door. We were told by the siemen's representative to not use the machine at all, as the motor may be burnt. etc. Today when we start the machine, it runs fine. what could be the reasons for this? do we have to replace the machine?
    Scholar:
  • 59 Answers
Front laod washers have a heater element The siemens is mounted at the front of the drum Most likely the heater is burnt out and will need to be replaced. not a difficult problem. The heater has probably burnt itself into an open circuit situation and so the machine now still works. it may not work right through a cycle if temperature is selected other than cold.
You should not have to repalce the machine for the sake of a heater if tis is the case. Why not call knowlegable technician to ascertain this problem. For someone to assume the motor is burnt without looking is not thorough. The banging noise may have been the drum hitting against the burnt out heater element. Good luck
Posted on Aug 01, 2010
Siemens iq500 washing machine. WD15G460GC PLEASE ASSIST!!! I've seen previous responses where to solve the problem people suggest holding start/reload, however this isn't helping. The key symbol is...
not sure if this was suggested but Siemens suggests unplug the machine, plug it back in and wait a few seconds, then select a cycle. The locked door should release.
Feb 06, 2018 | Siemens Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
My siemens dishwasher model SL34A002UC/22, does not go to the dry cycle. It keeps washing and stays on the last minute and doesn't stop. Could it be the control board?
it is probably the timer , if u open it and pull off the plastic lining inside you can get at it just unplugs pay attention to the little peices and springs so u can put it back together ...
Apr 08, 2011 | Siemens Dishwashers
Siemens waching machine is on child lock how do I unlock it?
Select the mode in which the machine was running. And then press timer (Clock symbol) for 5 or more 10 sec. The lock will be removed
Jul 05, 2010 | Siemens WFXD8400UC Front Load Washer
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite model 16574
press (high temp-wash) button and then ( heated dry)
do that 3 times in that order within 5 seconds. So it looks like this:
(high temp-wash) ( heated dry) (high temp-wash) ( heated dry) (high temp-wash) ( heated dry)
That will start a short diagnostic cycle (last about 2 minutes) that will clear the blinking light and allow you to use the dishwasher. If the light comes back, your drying cycle has failed and you will need service.
Oct 28, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
