Intuitive Eco IW711E shows a fault 66 -- what does thios mean or what is the problem. It does not switch off the water inlet -- ie water continues to fill and spill over. Vinod Naidu
fanny
  • 146 Answers
SOURCE: F&P Intuitive eco (IW811)
Even though the resistance of the valve is normal, doesn't mean that it cannot be faulty. Try swapping the valves around and see if you still get cold water coming in through that valve. If not, then the valve is faulty. Don't forget to put the cold valve back where it belongs. There is a difference between the hot and cold valves( cold valve is a proportional valve) but for testing purposes they can be swapped around. To set the size you have to switch the machine off at the wall. Switch it back on again. Wait for all led's to go out. Press & hold the start/pause button while you push the power button. Switch off again and it should be o.k.
Posted on Nov 03, 2007
  • 351 Answers
SOURCE: fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Posted on Mar 03, 2008
  • 3 Answers
SOURCE: Intuitive Eco
Would suggest doing a full hot empty load, using bleach according to bottle instructions. It sounds like a build up of scum from washing powder, fibre from clothing etc. Can also be caused by overuse of fabric conditioner.
Posted on Jun 11, 2008
SOURCE: Intuitive Eco IW811 washing machine
I have the same problem , was told that it is the RPS rotary positioning system, cost about $200 to get someone out to fix it.
Although I did reboot it and it went through the wash ok.
Posted on Sep 01, 2008
SOURCE: what is code 37 intuitive eco
replaced the water pump. It was failing intermitantly
Posted on May 06, 2009
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My washing machine Fisher&pykel/ intuitive eco /model:iw712,always when washing stop and give message(remove-drip dry items then press start to continue .please advice whats wrong and how to fix...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Aug 09, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Morning, I have a Fisher and Paykal intuitive eco washing machine that continually beeps 'No cold water'. What would cause this. Thanks
Hi just read your posting.Now have you removed the cold water inlet hose from the machine end and checked to see if the water is coming from the tap and throe the hose?If you have then the fault could be faulty Water Valve,or faulty Control Module.Please reply and confirm whether you have cold water coming from your cold water tap or not and I can guide you throe the repair of this fault.
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Water will not flow constantly into machine
Check the water inlet valve. Unplug the machine and turn off the water. Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 16, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco fisher & paykel washing machine
this is a pretty clear cut fault (66). It is a problem with the pressure transducer (water level). The only cure is to replace the motor controller (which is the lower of the 2 modules in the console)
Oct 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
