Question about Frigidaire Kitchen Ranges
I have a fridigaire electrical range model FED367DSA ser #F34717223. I have had a repairman out for a F9 problem several times. He has replaced the mother board control 2 or 3 times. The last time he was here he asked us to get a master electrician out to replace the brakers. This has all happened in the last several months. The last replacement was done the 26 of July. Tonight while cleaning the top of the range I leaned on the congtrol area and the same problem occurred. The range is approximately 7 years old.
SOURCE: Jenn Air JGS8850ADS Range
this model is a lemon. Maytag knows and does not care. My panel has been replaced 8 times already. Stay away from Maytag.
Posted on May 25, 2007
Krazytech
  • 725 Answers
SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
Posted on Sep 08, 2007
SOURCE: Kenmore Elite Range/Oven problem.
We had this problem as well, our's locked and we were not able to unlock it.
We found that holding down the stop/clear button on he bottom right of the key pad for 3 consecutive seconds releases the lock.
The locked oven wording will blink for about a minute and then the oven is released completely.
So frustrating...I accidently hit the option while cooking. Talk about panic. I needed to use the oven.
Posted on Oct 21, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
  • 7 Answers
SOURCE: Model S176W Jenn-air F-1 code flashing and beeping
Not sure what an F1 code is on that unit, but an easy check here,
shut off unit at breaker, remove face and unhook touchpad (ribbon) from the ERC. Turn the breaker back on, If the error code stops and it doesn't beep, the touchpad is most likely the problem. If it continues to beep and throw code, could be the Erc, (or something else telling the erc somethings wrong.) without knowing the F1 fault code, I wouldnt know where to start looking!
I would probably recommend a tech to reinstall the new Erc and or touchpad. Most new electrical components require extreme care when handling/installing, and a tech will know the proper procedures. Good Luck!
Posted on Sep 12, 2009
F9 error code while cleaning oven
F9 = oven door lock failure
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If that looks good, replace the lock. What is the complete model number? Look in the oven door area.
Feb 14, 2013 | Whirlpool SF315 Dual Fuel (Electric and...
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
Jan 16, 2018 | Maytag MEW5530D Electric Single Oven
Error code f9 is telling me what
Hi, F9 indicates a door lock problem. If no problems are found with the latch mechanism you will need to replace the ERC/clock module. For diagrams and illustrations enter your model # at
appliancehelponline.com All parts come with installation instructions.
Thanks for using fixya....
And please don't forget to rate me..
Oct 28, 2010 | Maytag MER5775Q Electric Kitchen Range
I have a code coming up saying F9 when i try to turn on the oven
F9 indicates a door lock problem. If no problems are found with the latch mechanism you will need to replace the ERC/clock module. For diagrams and illustrations enter your model # at www.appliancehelponline.com All parts come with installation instructions.
Apr 09, 2010 | Maytag MER5775Q Electric Kitchen Range
Our Fridigaire range oven will not shut off. In
F1 is a bad oven control. (clock).
It must be replaced.
Unplug the range.
Remove the screws from the rear panel.
Remove the wires from the (clock).
Replace the EOC (clock) with a new control and bake me some cookies.
Feb 02, 2010 | Frigidaire Ovens
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have a fridigaire stove self cleaning model fefl77abf i pushed the cleaning button it said it was locking the door then the stove started beeping and flashing f9 and the door is not locked could you help...
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Feb 01, 2009 | Kitchen Ranges
Kitchen Ranges Logo
52 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
