Question about Fisher and Paykel Fisher & Paykel Washer
Washing machine smartdrive 601. Turn power on to machine, all lights come on for an instant and there is a beep, as per usual. When you press the power button on the console there is no response. Unable to enter diagnostic mode either.
    President:
  • 1,554 Answers
This sounds like an issue with the Motor Controller Module and/or Display Module. Unplug the machine then let it sit for at least half an hour to eliminate the possibility of an electronic glitch. Check the wire harness connection between the Motor Controller Module and Display Module if the problem is not addressed. Remove the 2 screws from the rear of the console then raise the console for access to the Motor Controller Module, Display Module, and associated wiring. Check to make sure the wire harness is intact and and fully inserted to both. The connections must be snug fit and corrosion-free. Reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals.
Consider replacing the Display Module if the problem still persist then the Motor Controller Module if the problem is still not addressed.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 01, 2010
New Control Panel instald all it does now is beep open lid stop beeping close lid nothing happens lights stay on help please
It is important to set the size switch setting into the Motor Controller's memory whenever a replacement Motor Controller and or Display Module is fitted
To set the size switch turn the power on at the wall and off at the machine. Press and hold the TEMPERATURE UP button then press the POWER button. SmartDrive will give 4 short beeps and the pattern of LEDs will change.
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for (8.0kg) (650mm wide). • Press POWER to exit this mode.
If this doesn't work let me know
Jul 16, 2015 | Fisher and Paykel GWL11 Top Load Washer
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Smart Drive 601 does not drain
with the machine plugged in and turned on but not powered up this is what to do
press and hold down the start button, then press and hold down the power button (hold down for 5 seconds) the washer may beep up to 3 times during this process
next remove fingers from buttons, then turn off machine with the power button, then turn on again and only press the start button this will now reprogram the computer
let it run untill end of cycle and this should fix prob
Jun 11, 2009 | Washing Machines
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
