Question about Jabra BT350 Bluetooth Headset Headset
Bluetooth syncing I have my bluetooth and i cannot sync it to my phone because i can get my phone into discovery mode but i cant get my headset in discovery mode. All it has is a volume up and volume down button and one button to answer calls. I now it has to do something with holding the button to answer calls but just holding it down doesn't work or clicking while searching doesn't work so im kinda lost. Thanx
  • Anonymous Nov 29, 2008
    i cant find the sync option in my menu of my g'zone
  • Jameison211 Dec 02, 2008
    my headset doesn't what to turn on at all after i had charge it for 24h? what should i do?
    Guru:
  • 160 Answers
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
When asked for pass code enter 0000.Phone should show connected to bluetooth device.
Posted on May 10, 2008
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
How do i sync my ht820 to my samsung flip phone, phone says place bluetooth device in discovery mode and I dont know how to do that\
To connect your headset to your phone, press and hold the "M" button on the left side of the headset for 6 seconds until the indicator light turns on and remains steadily lit.
Next, put your phone into pairing mode by going into your Bluetooth settings and searching for a device. Once your phone has found your headset, you can sync them together.
May 03, 2011 | Motorola Mobility HT820/ 98689 Bluetooth...
When i try and sync my bluetooth it says it's searching but nothing ever comes up.
Some, well most, headsets or other Bluetooth peripherals tend to be in "hidden" mode so that only people with physical access to the device can pair with them.
Your solution may be as simple as hitting a button on the side of the headset to put the device in to "discovery" mode. Try searching the internet for the bluetooth device's user manual and look at the section on pairing for more help.
Feb 25, 2011 | Apple iPhone Smartphone
I cant find the bluetooth 925 with my bluetooth search what to do??
try holding the power button on power up until it enters sync mode then the device should be able to see it ok
Feb 10, 2011 | Plantronics Discovery 925 Bluetooth...
I cannot get my motorola H700 to sync with my iPhone 3g. Bluetooth won't go into pairing mode
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Motorola Mobility H700 Wireless Headset
How do I sync my old plantronics 230 with my new phone?
When you turn the bluetooth on, just hold the call control button until the light flashes red and blue, which means it's in discovery mode. In the 120 seconds that it is in this mode, search for the device on your phone, and it should show up for you to connect.
Feb 09, 2010 | Plantronics Explorer 230 Bluetooth Headset
Just got a new phone, and can't sync my bluetooth to it. Headset is "Just Wireless", phone is Samsung a777.
You need to make sure your wireless function is turned on, on your phone. Look under settings and tools go to add new device. You also need to place your headset in discovery mode. read the directions that came with the headset it will tell you how to do that.
Oct 17, 2009 | Just Wireless Bluetooth Headset Wireless...
Wont sync with iphone
Make sure that the headset and the phone are both are in "pairing" mode. Even though the iPhone's bluetooth is on you will have to select the headset from the phones bluetooth menu. To get the headset into pairing mode press and hold the "+" sign for 3 seconds. Hope this Helps!
Jun 08, 2009 | Apple iPhone 3G
How do i put a motorola h700 bluetooth into discovery mode
close the mic and push down the button until the light shows purple. Flip open the mic and it should be steady purple. it's now in discovery mode and you should be able to sync it to you phone.
Feb 14, 2009 | Motorola Mobility H700 Wireless Headset
Ford Sync and my envy2 bluetooth
Be sure that the enV2 is being put into discovery mode and so is the Ford.
Dec 31, 2008 | LG enV VX9900 Cellular Phone
Jabra BT350 Bluetooth Headset Headset Logo
716 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
