Question about Mitsubishi WS-65807 65" Rear Projection Television
Mitsubishi ws-65807 no sound or picture
Hi
I have a mitsubishi ws-65807. I have no sound or picture , but i do get the menu screens. also the tv will memorize the channels ..any ideas...?
thanks
Ken
  • kengcad Apr 25, 2008
    i checked ..there isnt any...the crts come on...i get the on screen displays ,menu,.etc..but no picture or sound
    Scholar:
  • 186 Answers
Something related to the video boards. Check all inputs first, then check ribbon cables to the video board. Be careful of high voltage if you open the cover.
Posted on Apr 25, 2008
    Genius:
  • 1,694 Answers
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Posted on Apr 24, 2008
SOURCE:
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
I have a Mitsubishi WS-65807 Projection Tv and while I was watching a program the picture went to a black screen. The audio works fine and when I go to the Menu it shows up fine. Any input as to the...
Thats usually a vertical issue since the menu still works. I would check the solder on the vertical IC and also the Vertical yoke plug pins. Often solder can develop a small crack around the pins and resoldering will usually fix the issue in most cases. The other item could be a leaky CRT has dripped some coolant on some of the components in the vertical circuit so I always check the board for any sign of a clear sticky residule on the boards which indicate dripping CRT coolant.
Jun 07, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I have a Mitsi WS-65807 65" Played Wii for about two hours. Lost sound then picture. Now it wont turn on. Just get a warped bluish screen with lines. Any Suggestions?
Well i need more info. have you tried unplugging the tv for around 60 seconds? Was the "warped bluish screen" right before it died. Or is this when you turn it on it happens?(Bluish screen)? Because if no power at all and no picture at all. Could be Power supply. If you have some sort of picture with blue lines that are stable? You have a convergence problem. Get back to me with info i can help.
Dec 26, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 Won't turn on....
it could be the bulb the lights u are seeing should be green not red.
Jan 14, 2009 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi ws 65807 sound with no picture
push qv and 9 on your remote and a screen will come up and follow the directions to correct your problem.
Jan 05, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
TV Image bending
maybe you have a magnet near it?
Feb 26, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
266 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
