Question about Panasonic KX-FPG391 Plain Paper Thermal transfer Fax
Check film message persists even after new film installed
  • 32 Answers
The Film is not genuine install genuine film & it will be fine...
Posted on Aug 03, 2010
Transfer film not installed Fargo HDP600 cr100
Double check to make sure the film is installed correctly. The printer senses a chip, located on the roll, to determine - Type, Amounts and Physical presence.
If this problem persists, go to HIDglobal.com. Under the Support tab, click Drivers & Downloads. Populate the drop down menus with make and model. From here you can view all the recent software versions.
Scroll to the bottom of the page, under Misc. Download the Fargo Workbench utility. This program enables you to automatically update firmware. It is also a very useful tool in diagnosing issues.
Sep 24, 2014 | Fargo HDP600 Thermal Printer
Model # GSD2304K00WW leaves a white film residue on the dishes. A new pump has been installed, but the problem persists.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 07, 2010 | GE Dishwashers
New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Dec 17, 2009 | Dell 926 All-In-One InkJet Printer
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Error message displays Check Printer (5200)
First power it down and wait for about 90secs.If the problem is noticed only when it receives signal from the system to print, the cartridge(s) is bad and should be replaced. If the flashing starts as soon as the printer is powered and remains persistent the cartridge(s), carriage and/or the optical cable(film) are faulty and should be checked. Good luck
Apr 28, 2009 | Office Equipment & Supplies
Calibration cannot be performed Error
I had the same problem when upgrading to mac os x. I was trying to scan directly from Photoshop but got the calibration message. I tried the two solutions given at the Canon website but they didn't work. I ended up downloading the Toolbox application to scan directly from there but the same message appeared. After installing the Toolbox application I unistalled the driver (11250) and reinstalled it. I opened Photoshop and tried scanning and the calibration window appeared only this time it didn't stop to give me the "Flim Adapter" warning. I must point that the scanner lid was open when this happend but I'm not sure that had anything to do with it.
So apparently it works if you have the Toolbox installed prior to installing the driver. The driver, Toolbox application and unistall driver can be found at Canon's website. Hope this helps.
Ciao!
Aug 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
Camera goes into Shut Down Mode & Flashes the Letter H
Hey sonax,
This H error message means either the film is loaded incorrectly, or there is an internal malfunction in the camera. To determine if the film is loaded incorrectly you should take the film and the batteries out of the camera then reinstall the batteries and try taking a picture without film in the camera. If the camera allows it then the film was loaded incorrectly and I would refer to the camera manual for directions on how to load the film correctly. If the H error message persists then there is most likely an internal malfunction and I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Canon Sure Shot 65 35mm Point and Shoot...
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
Paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Sep 19, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
Premature Film Rewinding
the only thing that I could think of when I read your situation is, that you might not be using a DX coated films. see, the camera reads the bar code on the film and maybe it is not the same program. check the camear manual and make sure you are using the same kind of the suggested film in the manual. good luck
Apr 11, 2007 | Nikon N65 35mm SLR Camera
Panasonic KX-FPG391 Plain Paper Thermal transfer Fax Logo
116 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
