Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Equator EZ3612 will not rotate or spin.
I just bought a used Equator EZ3612 CEE. First time trying it everything appeared to work - filled, rotated drum, emptied. After the rinse cycle started, I turned off the water supply at the sink.
Went out for a bit, came home and clothes steaming hot but wet. Had to wring out a pair of socks. Tried rewashing, this time leaving the water on during the entire cycle. Everything is working now except the drum won't tumble or spin during any cycle.
I followed the complete reset instructions and tried to wash another load. Drum still will not tumble or spin.
Help please?
  • 249 Answers
SOURCE: EZ 3612 CEE Equator front load washer
Its the main drum Bearings!or else if your lucky it might be a spring off! or broken! up on top remove top to see!! it s not the belt
Posted on Dec 13, 2007
  • 105 Answers
SOURCE: Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Posted on Feb 02, 2008
  • 1894 Answers
SOURCE: Burns clothes!
hello sir
Posted on Feb 08, 2008
SOURCE: EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Posted on Jul 06, 2008
I HAVE THIS MACHINE AND IT WORKS GREAT....THE ONLY PROBLEM I HAVE IS THAT MY CLOTHES ARE EXTREMELY WRINKLED AFTER THE DRYING CYCLE IS OVER. I DO NOT FILL IT MORE THAN 2/3 FULL AND I USE A CAP FULL OF...
Since you stated you are already using fabric softener, it sounds like you are over-drying your laundry. Try reducing the dry time and hang your clothes immediately.
Jan 30, 2011 | Equator EZ 3612 CEE Front Load...
Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Equator Wash dial just spins
just bought this ez 3600cee it says its ventless ,but yet came with
a venting duct work why?
Nov 29, 2008 | Equator EZ 3600 CEE Front Load Washer /...
ChicagoRandy,
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
Doug
Feb 24, 2008 | Equator EZ 3612 CEE Front Load...
i think the belt of the motor or the motor it self..... bad is sound produced only when something is loose due to over used... i suggest that to replace belt or motor...
Nov 09, 2007 | Equator EZ 3612 CEE Front Load...
Missing part
Call the Equator store in Houston. They're real nice: (713) 464-3422 / (800) 935-1955.
Sep 21, 2007 | Equator EZ 3710 CEE / W Ventless...
Equator EZ3612 CEE
If you still need assistance on this let me know and I can provide you with the procedure for the same.
Sep 15, 2007 | Equator EZ 3612 CEE Front Load...
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
71 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
