Question about Packard Bell Easy One Silver 2120 Notebook
Powering on... when i press the on button doesn't won't work...
    Sergeant:
    Champion:
  • 301 Answers
Chek the batery or check the adaptor voltage , need a 40 V
Posted on Aug 01, 2010
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
No power when front button is press but on back of unit there is a flashing green light
Unplug the computer and wait for a few seconds. Plug it in again and press the power button. If this doesn't work, you will need to take it to a service agent as it won't be user repairable.
Oct 21, 2012 | Compaq SR5703WM -24407
My 3ds xl screen has frozen
Hold down the power button until the screen goes black. Then press the power button to turn it back on. If this doesn't work, you'll have to remove the battery. If it still won't work, send it to Nintendo to fix; your limited warranty should still apply if it's the XL.
Oct 19, 2012 | Nintendo 3DS XL
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
The disc draw doesn`t open when i press the open button
standing up or laying down?
when standing they sometimes stick, lay it down and if it still won't open then press down on the casing just above the eject button.
if that doesn't work then the unit will have to be opened, the dvd drive taken apart and completely cleaned.
Nov 15, 2011 | Microsoft Xbox 360 Console
Buttons stopped working
Your electronic control has problem the relay and magnetic contactor won't work. Better check your control panel first switches has no contact or your power supply for your electronic control has no power or check the fuse. Try to press the magnetic contactor in few seconds and see if the compressor and fan works. If doesn't work your have power on your electric wiring and and power.
Sep 11, 2011 | LG Electronic Window Air Conditioner
I used to be able to make announcements on an 18D by pressing intercom and the top right button. After a power outtage our phones have been different. How can I program or make announcements again?
Call in a pro. it sounds like you lost all your programming with that power outage.
Depending on your processor type, you may have to re-program teh entire system, or just restore a backup....
Sep 06, 2011 | Lucent PARTNER18 Corded Phone
Computer working perfectly fine one day, the next computer won't turn on for no apparent reason. when switching the power button on, computer begins to boot up for a brief moment, then automatically...
It's probably your logic board. One thing you can try that may help you out is to take out the battery (if you can) and press and hold the power button for 10 seconds. If it's a capacitor problem on the board that should discharge it. If that doesn't work then you should probably try to turn on the computer while holding CMD + Option + P + R to reset the PRAM. If that doesn't work then you're probably going to have to seek professional help.
Aug 04, 2011 | Apple Computers & Internet
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
My dish remote will not work with my naxa tv
Hey sevenwindham,
If the remote won't work it may need to be programmed to the TV. You can personally look at the steps in the link below, just look up the model of your remote. The steps to program your remote are also provided
http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If that doesn't work you can also try the Power Scan listed below.
Power Scan:
1.) With the TV on, press and hold the desired mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, the TV will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
If you have any other questions let me know!
Tommy Faust
DISH Network
Jun 15, 2011 | DISH Network IR Remote Control
Packard Bell Easy One Silver 2120 Notebook Logo
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
