Question about Toshiba 32HL67 32 in. LCD Television
It turns off after watching for a while, but can stuill here sound? is that the bulb
  • 11,361 Answers
Not likely.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 01, 2010
Why does turn signal sound all the time unless the br(ake) is pressed?
Taryn, sounds like a faulty turn signal switch, or multi function switch is defective. Check all the bulbs and sockets first for damage wires, burnt wires or bulb socket, cheapest part to change besides bulbs would be the signal flasher or the signal relay if you want to go this route. Below are trouble shooting links you can read or watch.
press the helpful button and follow me on fixya for more tips
Turn Signal Switch May Fail and Cause Clicking Noise Chevrolet Tahoe...
How To Change Turn Signal Wiper Control Switch On Ford Lincoln Or Mercury
How to Replace Your Turn Signal Relay in Lincoln Navigator eHow
Blinker light flasher change out on 2003 Ford Expedition
Feb 10, 2016 | 2004 Lincoln Navigator
Having trouble with my turn signals. The bulbs light up but they don't always flash. Sometimes they flash normal, sometimes fast (as if the bulb is going) and sometimes not at all.
From your description, it sounds like the flasher relay is on its way out. See the link to the YouTube video showing the location for a 2004 Mountaineer. Yours should be in about the same place.
https://www.youtube.com/watch?v=qTEsGBokJiU
Jul 16, 2015 | 2003 Mercury Mountaineer
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an...
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Jan 17, 2011 | Mitsubishi WD-57733 57" HDTV
Is it possible to replace the bulb in this tv or something like that? I was watching it the other day when a loud pop occurred and there was some burning smell accompanied by the picture and sound going...
Shop around for the Big Screen repair Tech. Shop.The problems u discribing,the tv have more than a dead projection bulb.Circuits boards have burn components,must be trouble shoot and replace first.Before even know the static of the projection bulb.
Jul 16, 2010 | Sony KP-53S65 53" Rear Projection...
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
Sound problem, then TV wont start up.
Did you ever figure out the problem? Mine just started doing the same. Can you email me at BrianLatch @ msn.com spaced for SPAM.
Jul 13, 2009 | LG 52SX4D 52" HDTV
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 32HL67 32 in. LCD Television Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
