Question about Canon PowerShot A540 Digital Camera
Canon powershot a540- using video mode and I do not want sound recording
Hi I want to use the video feature but AI don't want to record sound while doing it is there a way to do that
    Novelist:
  • 130 Answers
There is no way to disable the audio on the camera unless you cover the microphone which I wouldn't really suggest. You would have to remove the sound later once you upload the video to your computer and put it into Windows Movie Maker or some other editing software.
Posted on May 30, 2008
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon powershot SD1000 video playback problems
Unfortunately, no. Time-lapse video works by taking fewer frames and then displaying them at normal speed so as to give the impression of time going by faster than in reality. Thus, the camera simply hasn't recorded all the information it would have in normal mode, and there's no way to recreate that information. Think of reading just the first line of every page of a book: you'd get through it quickly, but you'd also miss some things.
Now, if you'd shot in slow-motion, then you could throw out some frames until you got to normal speed.
Jul 26, 2010 | Canon PowerShot G9 Digital Camera
How to use the timer on Canon powershot A540
From the menu, select Drive Mode (third item from the top) then one of the self-timer options.
May 20, 2010 | Canon PowerShot A75 Digital Camera
I bought my camera in july 2006 - recently it runs
I´ve got the same issue. If you use the batteries that were in A540 in another camera, does it still work?
Jan 11, 2010 | Canon PowerShot A540 Digital Camera
I have to shoot a video within a fast-approaching time frame HOW
Turn the selection knob on the top of your camera to an icon that sorta looks like a video camera on a tripod, then push the record button to record.Video mode autonatically records sound. You might want to add auxilliary kighting if shooting indoors.
Good Luck!
Jun 16, 2009 | Canon PowerShot S3 IS Digital Camera
Video playing in fast forward with no sound
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
Change resolution on Canon PowerShot A540
Follow the instructions in the "Changing Recording Pixels and Compression" section of the advanced guide (page 31 in my copy). If you need the manuals, you may download them from here.
Dec 25, 2008 | Canon PowerShot A540 Digital Camera
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Canon powershot 9
This should be problem solved for future recording.
Sep 20, 2008 | Canon PowerShot G9 Digital Camera
The recorded movies are fuzzy
Hey Jennyw,
I would make sure that you are shooting the video on the highest recording pixels available, which on this camera is 640x480. You could also increase the frame rate to 60 frames/second. Directions on how to do this are on page 41 of your user manual. I have included a link to download your manual in case you no longer have it. I hope this helps!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=12942#DownloadDetailAct
Sincerely,
Allan
Go Ahead. Use Us.
Jun 20, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
