Question about RCA DISH Network(r) 311 Satellite System
Set up unit in phoenix ny
Want sombody to help set up in camper
  • 78 Answers
The best way is to get a tipod for small dishes and a compass. practice aligning it up at home enough to understand where south is and how to watch out for obstacles such as trees. if this is not what you need, then i need more info on the camper and how you are trying to set it up.
Posted on Apr 29, 2008
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
How to set dometic rv air conditioner control
Cleaning the condenser and evaporator annually will make a huge difference in the cooling ability of the motorhome or camper trailer RV unit. Lubricating the A/C fan motor may help extend the life and performance of the unit itself. http://fugenx.ae/
May 14, 2013 | Dometic Rooftop RV Air Conditioner
Carrier unit in camper wont come on ..dead..fuses ok..?????
Have you checked breakers in panel, to make sure one isn't tripped?
What type, year camper is this on?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Where is the drain?
There are grooves on both sides of ac unit on a camper and it drains down the roof to a little gutter that travels the water towards end of camper and drains. Most of the time down the side of camper, but if these Grove are stopped up it will not allow it to drain and cause it to overflow inside camper. If filter is very stopped up or evaporator coil is stopped up, fan not running, low on refrigerant, or having the thermostat set way to low can cause it to freeze up and when this water thaws out it is too much for the drain to handle and also ice could be sticking being the drain pan melting causing it to go in your camper. I would check filter and those drain grooves first.
Sep 17, 2012 | Coleman Mach 15 Air Conditioner
I can't here the ring, when sombody phone me.
usually you can go into your menus find ringer volume and set it as you want it. It may be set to silent. What phone do you have?
Jun 10, 2012 | Cell Phones
I have an email account with tiscali but when i send mail it does'nt let me know its sent iv.e ticked alll the boxes in settings can sombody please help
best thing to do, is set up a gmail mail account or msn messenger account and then you can transfer all your emails sent and received to your new email address also all your contacts too... g mail will do all this for you automatically.
Nov 21, 2011 | Computers & Internet
I have a camper with a Dometic rooftop air conditioner. The Model No. appears to be 3310700.012. The thermostat it the type that fully shuts off the unit (compressor and fan) when the set temperature is...
no both the options A and B which you gave cannot be done.yes option B is possible in some form.but in this case fan will not shut down and this will burn the fan motor and even make the fan wirings short/.so option B is also not advisable.but the problem is either in the thermostat or in the thermostat shut-off relay.the voltages needs to be checked by meter to confirm the fault. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 15, 2010 | Dometic Rooftop RV Air Conditioner
Help, Brand New A/C unit drippin inside camper
they do that its normal operation, you will get varying amount depending on your location and humidity. If it is not balanced or installed right it drips in the camper.
Aug 16, 2009 | Dometic Rooftop RV Air Conditioner
I have a Class C motorhome. The unit is in storage and when I arrive to check on the motorhome, the alarm is going at low alarm or needs replacing noise. I had the unit checked as well as the motorhome....
hi chuck. the source of the carbon monoxide is outside of your unit. for example other engines running near by sending fumes into your unit and setting off your alarm
Jun 25, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
Brake controller not communicating w/ 7 pin connector
what type controller did you install? Is this a camper or trailer? Is the controller hydraulic plumbed into master cylyder? Important to know how to adjust rheostat for sensitivity. If set at minimum the system is basically on the edge of not sending any signal to towed unit. The intructions should explain how to make this adjustment. If set too sensitive trailer brakes will lock up before the tow vehcle starts to brake. Controller should be set so trailer starts braking just befor the tow vehcle. If not the trailer will tax the tow vehicle brakes by pushing. Its set right when you feel the combination stretching out. trailer first then tow vehcle. Good luck and remember, if truck brakes first and too hard you risk a jacknife. All light voltages should be system voltage. Brake voltage is variable depending on setting on controller. Understand your breakaway brakes and how they work. breakaway breaks require an auxillary battery. Again, good luck and you know where to find me if I can be of anymore help.
Apr 13, 2009 | 2003 Chevrolet Silverado 2500HD
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
