Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Icemaker gets water but does not make ice. When
Icemaker gets water but does not make ice. When we go out of town and refrigerator is not used it does make ice, but it stops a couple of days after we get back. Items in freezer stay frozen and new items freeze normally when we are there. I tried turning freezer setting colder and that did not work.
It is a Whirlpool Gold model GS6NBEXRL01
    Genius:
  • 1,478 Answers
If your ice maker is not producing any ice at all, it could be due to various reasons. Firstly, check the right side of ice maker for a wire. The wire will be in an erected position, if the machine is turned off. In such a case, lower the plastic lever present in there or the wire directly if there is no plastic lever. This should be enough for your ice maker to start functioning once again.
There could also be a case of blockage in the ice maker fill tube. If this is the situation, use a hair dryer to melt any ice stuck in there which is causing the blockage. Replace the tubes if necessary. Check the ice maker assembly for any cracked up or broken parts. Especially check the gears and plastic arms along the ice rake, as these are more likely to break down compared to other parts. Replace them if needed.
Take care.
Posted on Aug 01, 2010
  • shufftpc Aug 01, 2010
    Thank you for your reply. I don't know if you saw in my original comments, but the icemaker works in our absence, but not during normal refrigerator usage. I have tried setting the freezer control to colder, even though everything stays cold and freezes normally with normal usage, but that has not helped either.
    Any other thoughts with this particular situation? Like mentioned, it is very odd that it works in our absence but not when we are there. It is getting water and freezing the cubes when we are there because you can feel the cubes in the icemaker. It is just not cycling through and releasing the cubes when we are there.
    Thanks
  • Jimoh Adeleke Muyideen Aug 01, 2010
    This is a troubleshooting steps to fix ice maker problem, check one after the other to see how it fix the problem of your ice maker.
    Check to see if something has caused ice to back up around the
    mechanism—this can cause the fill tube to freeze, blocking the
    mechanism. When ice cubes are small and seem to be getting smaller, it
    generally indicates a frozen fill tube.
    Check the water line
    that enters the back of the freezer for a blockage. Find the water
    shut-off valve behind the refrigerator or under the sink, turn it off,
    unscrew the copper line from the back of the refrigerator, put the
    copper line in a bucket, turn on the valve, and see if pressurized water
    pours out.
    Check the tap valve; a bad tap valve may cause the
    problem where the icemaker’s supply tube connects to the water pipe. If
    necessary, replace the inlet valve and the tap valve. For the tap
    valve, use the type that requires you to drill a 1/4-inch hole (as
    opposed to the “self-piercing” type). You can do this yourself, or call a
    repairperson or plumber to install an inline water filter when
    replacing the valve.
    The water line attaches to a solenoid at the back
    of the refrigerator and then travels to the icemaker. The solenoid may
    be defective or may not be receiving power. You can try removing the
    sediment screen inside the solenoid and flushing it with water to clean
    it, and at the same time you can inspect any seals or diaphragms to
    ensure that they are sound. Unplug the refrigerator first. Unless you’re
    skilled at home repairs, this job is better left in the hands of an
    appliance repairperson.
I turned my water off when we left town for a month. After turning my water back on the ice maker has stopped working. Our refrigerator is a Kitchen-aid superba model and is approximately 4 - 5 years...
The issue is likely that the icemaker fill tube is frozen due to poor water pressure. You can use a turkey baster to thaw this tube which fills the icemaker. Make sure you use plenty of hot water because they often freeze back several inches!
Sep 11, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
No water ti ice maker . I have replaced the solenoid and complete ice maker and still no water to icemaker.?
You're alredy replaced the Water Valver - Still Not Working.
Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable goes all the way through. Hook back the water line to the icemaker. You will have ice soon.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Jun 01, 2010 | Frigidaire FRS23KF7AW Side by Side...
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Mar 17, 2010 | Amana ATB1832AR Top Freezer Refrigerator
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please totalcarefl@yahoo.com
Sep 09, 2009 | Jenn-Air JCD2295HES Side by Side...
We have a Maytag side by side refrigerator. We
Sounds like your icemaker is overfilling if you are finding a layer of ice in your freezer compartment. I would change your water valve located in the back of the unit. Or look at the icemaker to see if there is ice cycles hanging down from the tray. If you do not see any, you may want to look at your freezer drain to see if it is clogged causing water to be drained in your home. Coulc be several different things honestly. Hope this helps!
Apr 08, 2009 | Maytag MSD2656G Side by Side Refrigerator
Ice maker will not work
check icemaker lever you did not turn the ice maker off
Mar 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
