Question about Kenmore 64802 Top Freezer Refrigerator
My frige is hot inside and the freezer is not that cold
What is wrong?
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Frige cool freezer warm
IS the compressor running and is it hot?
Dec 08, 2012 | Maytag MFD2560HES Bottom Freezer French...
My frige and freezer is staying cold but water is leaking from the top of fridge where cool air is pushed in from freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 27, 2011 | Microwave Ovens
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
May 31, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
The Frige is not cool, only the Freezer is Cold.
Hello Chrofattah,
I understand that you are having a problem with you refrigerator not cooling but the freezer is working fine. I have wrote a tip that will show you how to fix this problem below is the link.
Freezer cold, Fridge Hot
Thank you for choosing FIxYa.com
Justin
May 08, 2011 | Daewoo Refrigerators
I have a ge frige that the freezer works but frige is warm
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Freezer frozen on bottom and frige cold on bottom only. No airflow coming from vents inside freezer or top left of frige, freezer and frig warm at the top. Model is a ED25QF
check to see if fan is running in freezer if it is you may have a defrost problem if not replace the fan its the evaorator fan that is in the freezer
Mar 08, 2010 | Whirlpool ED5FTGX Side by Side...
Our frige and freezer will not get cold whats wrong
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Refrigerators
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
Fridge not cold, freezer fine...
look at the back inside wall of the freezer. you might need to put your hand on it to feel it. if you see or feel frost the you have a defrost problem. if its not defrosting the frost builds up and blocks air flow from the freezer to the frige so the frige cant cool. it will either be the defrost element, defrost thermostat or the defrost timer causing the problem
Nov 25, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
