Question about Sharp SF 2020 Copier
Error f1 en sharp sf 2530 - Sharp SF 2020 Copier
  • Sharp Expert
  • 316 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Posted on Aug 01, 2010
How can I change the toner in my sharp 2530 sharp
open front cover ,release green holder on the right,pullout developer unit add toner .
Apr 26, 2010 | Sharp AR-M237 Copier
Our copier sharp model sf 2530 has error code H5?can't find what this
Clear jams in the fuser unit (heat rollers) then enter these 4 keys P,=,C,= enter simulation number 14 press copy button and follow screen instructions. If none press CA key to exit.......copier may have already restarted.
Nov 22, 2009 | Office Equipment & Supplies
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Apr 05, 2009 | Sharp SF 2040 Copier
I have a Sharp SF-2030 copier and it is diplaying a F1 code.
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
Feb 21, 2009 | Sharp SF 2020 Copier
Sharp sf 2530 hang
I would suggest to throw that old thing in to a pond see if it will float..
Oct 24, 2008 | Sharp SF 2540 Copier
Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
May 22, 2008 | Sharp AR-M237 Digital Copier
213 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
