Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
How do i change the bulb - Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
    President:
  • 1,932 Answers
Please follow the steps to change the bulb.
1.Turn the television off and unplug the AC cord.
2.Remove the front speaker grill by gently pulling on each side. The grill will snap out.
how do i change the bulb - 1bb40b3.jpg 3.Using a Phillips screwdriver,remove the three screws that hold the recessed plastic cover in place.
4.Remove the plastic cover and set aside with the screws.
5.After removing the cover,you will be able to see the lamp cartridge.With the screwdriver,loosen the three screws of the cartridge. The three screws will not completely remove.
6.Gently grasp the metal handle and pull straightout (towardsyou).
7.Insert the new lamp cartridge securely into theTV.Donot touch the glass surface of the cartridge.
8.With the screwdriver,tighten the screws on the lamp cartridge.
9.Replace the plastic cover and screws.
10.Snap the speaker grill back into place by pushing It into place on each side with the palm of your hand.
thanx
Posted on Aug 01, 2010
How do i change side bulb in mitsubishi space wagon
Mitsubishi change side lamp bulb mitsubishi space wagon ...
www.fixya.com > ... > change side lamp bulb mitsubishi space wagon
Change side lamp bulb Mitsubishi space wagon related problems. Ask your Change side lamp bulb Mitsubishi space wagon questions. Get free help, advice ...
Mitsubishi Space Wagon 91 98 Sidelight Bulbs W5W 501 ...
www.ebay.com > ... > External Lights & Indicators > Bulbs & LEDs
eBayProduct Type: Sidelight. Operates: Sidelight. Further Information: These bulbs are a direct replacement for any W5W 5W (501) wedge bulb no matter what brand.
Nov 26, 2015 | Mitsubishi Cars & Trucks
How do change a bulb in a classicflame 23ef010gaa
How to Change a Light Bulb in your Electric Fireplace
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
Oct 29, 2015 | Cars & Trucks
How to change bulb
You can change the bulb from under the bonnet there should be a black rubber cover on the back of the light were the wires connect to the light bulb unplug light pull rubber cover remove metal clip then change bulb.
Aug 17, 2014 | BMW 318 Cars & Trucks
Change turn signal light bulb
Did you change the bulb or want to change the bulb? Also, if you want to change the bulb is it the front or rear? Come on man, be a little more explanatory!
Apr 18, 2014 | 1985 Chevrolet Camaro
Headlight bulb chevy traverse life
As I also had the dealer tell me it would be $120 - $150 to change I looked into it further. If you will remove the screws from the protective cover under the fender (just a few you do not need to remove the full fender cover). You can access the bulb. You will need to turn the housing and remove the bulb. Be sure to not touch the bulb as oil from your fingers will make certain you will be changing the bulb in a short time. Also I would use the standard bulb as the brighter bulbs run hotter and burned out very fast (2-3 months). If you turn the wheel your access to the bulb is easier. It is tight but by changing the bulb yourself you are saving a lot of money.
Sep 12, 2013 | 2010 Chevrolet Traverse
New signals not flashing
Depending on the year of your bike, If you changed your signals from a bulb type to a LED type you will need a Load equalizer. If its a bulb to another bulb, Check your voltage at the housing. A change in amps or watts for the bulb will usually only change the brightness, unless you have changed the bulb to an outrageous wattage or amps.
Jan 12, 2013 | Harley Davidson Motorcycles
I have 2006 Grand Prix How do I change head lamp?
Caution Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
Turn off the lamp switch and allow the bulb to cool before changing the bulb.
Leave the lamp switch OFF until the bulb change is complete. Always wear eye protection when changing a halogen bulb. Handle the bulb only by its base. Avoid touching the glass. Keep dirt and moisture off the bulb. Properly dispose of the used bulb. Keep halogen bulbs out of the reach of children.
Raise the hood.
Remove the headlamp assembly bolts from the upper fascia support.
Slide the headlamp assembly outward enough to release the headlamp bracket tabs from the slots in the upper fascia support.
Position the headlamp assembly away from the vehicle body to access the electrical connector.
Disconnect the electrical connector from the headlamp assembly.
Remove the headlamp assembly from the vehicle.
Disconnect the electrical connector from the headlamp bulb/socket.
Remove the headlamp bulb/socket retainer ring from the headlamp, by turning counterclockwise.
Remove the headlamp bulb/socket from the headlamp assembly.
Jun 13, 2009 | 2006 Pontiac Grand Prix
Left xenon ligth is not out... but has changed color from the cool blue ... to a slight pinkish color? is it the bulb or something else
xenon bulb has two electrodes and they will erode away if the bulb is old. The color that you see is probaby the erotion of the electrode mixed with the inert gas and metal halide. All HID bulb will change color over time. For example a brand new 4300K yellowish bulb will eventually turn into a 5000k color bulb which is purple and white
If your bulb is not too old but the colour has changed then that means your bulb has premature problem. Frequently switching on and off the bulb can age the bulb by up to 50%.
I strongly recommended to change both bulbs, so they have even color.
Cheers
Dec 17, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
333 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
