Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I can hear audio but cannot see anything on my tv
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 01, 2010
Reoccurring audio problems
All TVs today are actually computers which also receive TV frequencies. The audio has to be decoded from the digital signal then goes to an analog audio amplifier. When you hear no sound with the picture do you hear anything coming out of the speaker? A hissing sound when the volume is way up?
If you hear a hiss then the amplifier is working but not getting anything to amplify. This could be due to a bad solder connection or a problem with the CPU and/or a switching circuit. Without a schematic I'm guessing here.
The bottom line is, there's probably nothing you can do to fix it unless you're used to dealing with SM (surface mount) technology and can touch up all solder connections from the CPU to the audio amp.
Whoever is fixing the TV should be able to tell you where you're losing the signal from the RF decoder to the amplifier as long as the problem is not before the decoder (which is probably all in software that the CPU runs.)
Oct 05, 2017 | Mitsubishi LT-40153 LCD TV
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
I just bought the Sony MHC-EC99i and I don't know how to connect it to the tv so I can hear the audio from the tv to my speakers
Not knowing anything about your TV...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCEC99I click on "Operating Instructions"
Look at the section: Using Optional Audio Components.
Assuming your TV has an RCA audio output or headphone output, connect to the PC In. You might have to get an adapter. Select PC In to hear it. make sure the TV's internal volume controls are sending a "Fixed" audio output or its volume control will affect the output. Mute the TV or turn its speakers down.
Jan 16, 2011 | Sony Audio Players & Recorders
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
We have a Sanyo DP19649 and headphones dont work
Turn speakers off in sound menu if available. Then turn up volume to hear in headphones.
May 06, 2010 | Sanyo DP19648 19 in. LCD TV
Problem with tv and computer. No sound.
If you plug in headphones to the Laptop can you hear anything? If not check laptop settings
If you plug an ipod (or similar) into the TV using the same lead can you hear anything? What about with a different lead?
The method is to take "known good" parts and swap them into the system to find the failure point by replacing each part in turn until you confirm it is "known good" or faulty.
I suspect the lead but follow the procedure above.
Nov 28, 2009 | HP Pavilion dv9000z Notebook
Cannot hear anything but speakers are fine. hooked up to directv box, LED tv and blue ray player.
It may be that your hdmi wires are damaged or plugs are loose. Try to tune it.
May 06, 2009 | Audio Players & Recorders
I just bought a Dynex DX-LCD19-09 19 inch TV. I also have a Phillips home theater system. I have digital cable and I cant figure out how to hook it up to where i can watch regular tv but hear it through...
The only audio out jack on your TV is for the headphone on the left side of the TV. You need to purchase a 3.5 mm to RCA audio cable, connect the 3.5mm jack to the left side of your TV and the 2 RCA audio cable ends to the audio in of your Home Theater and then select AUX 1 or AUX 2 on the home theater depending on which jacks you plugged into.
Mar 09, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
My phillips tv audio doesn't work well
This problem might be related to a bad control board that controls the Audio and Video and other functions. It costs $180.00 to replace. Not worth fixing
Jun 21, 2008 | Philips 27PT6441 27" TV
How to fix the volume on RCA tv..
Look on back of tv see if there is a switch for internal & external speakers see if it is on or off ,if not go to menu in audio see if speakers are turn off or on.If this does not work you may have bad speaker or audio output ic. ThankYou for trying FixYa. Have a Nice Day.
Feb 18, 2008 | Televison & Video
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
771 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
