Question about Whirlpool LER4634J Electric Dryer
Our Whirlpool Dryer, model # ler4634e was working, heating everything but I unloaded it and loaded it and hit the start button, nothing. I can hear the timer working but nothing happens when you hit start. Any ideas? Thermal fuse as mentioned? Know where I can find one? Direct from Whirlpool?
  • 7,365 Answers
You have a starter button that went bad, you can order them from sears online
Posted on Aug 01, 2010
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
Jul 17, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer wont start
Check the door switch actuator (the piece sticking down that the door actuates when closing . Could have broken off . If there , and you hear a click , then thermal fus (white piece with 2 wires attached ) could be problem . Disconnect power and put the 2 wires togather. Reconnect power and see if dryer starts . I have never had to replace a push-to-start switch .
Jul 14, 2009 | Whirlpool Dryers
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
My whirlpool clothes dryer will not start.
Hello Rick,
Use this link to get information for your dryer.. it should provide you with everything you need. Get back to me if you are still having problems..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 28, 2008 | Whirlpool Dryers
Whirlpool Model LG7681ZSN1
check the door switch if it is working then a broken belt can cause this problem let me know how you make out
Sep 13, 2007 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
295 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
