Question about Thermador PRD486EDHU Range
The grill and both ovens stopped working on our Thermador 48" freestanding range. Are there hidden fuses that may have blown?
SOURCE: Flashing Lights on Thermador Oven/Range
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Posted on Jan 31, 2009
SOURCE: thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Posted on Feb 09, 2009
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
SOURCE: Thermador PG484GGBS: How to convert from Natural Gas to LP?
I just did it with mine, I called thermador and they told me the number of the conversion kit to buy for my model.
I bought the kit from the retailer and did it myself, not very difficult.
no explosions yet :)
nic
Posted on Mar 26, 2009
SOURCE: Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
Posted on Sep 10, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
VDSC4876GSSLP - Oven element wont heat . . Main oven started going in and out of "clean" mode, locking and unlocking the oven door while in use, then eventually stopped working all together. Fan and light...
If there is power to the unit (lights turn on) I would check the fuses and switches especially the one for door lock mechanism if you noticed a glitch. But a lot of times if you experiences problems after running a self-cleaning function, including locked door issue, the solution could be as simple as resetting a switch and no actual replacement parts needed. It all depends. If you are in Los Angeles, we could send a Viking repairman the same day you call us. : Viking Appliance Repair
Dec 08, 2014 | Viking 48" 6 Burner, 12" Grill Gas...
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
We have a MMV4205 BAS 1150 watts that just stopped working. It literally just stopped in the middle of running and shut down completely. It is like there is no power to any part of it - no clock, no fan,...
It's probably a blown fuse or the thermal cutout (TCO) or thermostat on the magnetron or on the oven cavity is blown.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Jan 29, 2010 | Maytag MMV4205 Microwave Oven
KitchenAid microwave #kcms135gss just stopped working no clock display , changed to diff outlet still nothing
You probably have a blown internal fuse or thermostat (one is on the top of the cavity and one is on the magnetron).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Jul 02, 2008 | Thermador PG486GEBS Stainless Steel...
Grill element stopped working in the middle of grilling roast pork. Blown element vs fuse - don't know where to find fuse box on oven. How do you tell if the element has blown? Is it easily repairable or...
there is no fuse actually in the oven
take rear panel off oven and use a multimeter to check continuity across the grill element. can also be the grill regulator if fitted
Jun 29, 2008 | Kitchen Ranges
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
Thermador PRD486EDHU Range Logo
23 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
