Question about LG WM-2277HW Front Load Washer
Lg 2277h won't spin
My 2277 hw is about 1 1\2 yrs old. It will wash and rinse but will not spin. It posts the UE (out of balance) code. I have even run it empty, but it still posts this code? Any ideas? thanks.
  • 489 Answers
More than likely, you have a problem with the balance ball sensor in the back of the unit if it so equipped.  It is located in the back of the unit and will require an LG qualified tech to see what's going on.
Posted on Apr 27, 2008
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
I got a ue code
UE means unbalance error. It means the machine can't balance the clothes in the drum so it won't spin to prevent excessive vibration and damage to the machine.
Usually opening the door and rearranging the clothes helps, or take some out then put onto a rinse and spin. If there is just a few items in then it will struggle to spread them around and balance.
Mar 02, 2011 | LG Washing Machines
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
BRand new installation of 1 year old machine we
I am a novice at front loaders but it sounds like it needs new suspension parts, namely springs, sounds like the machine had a hard life before you got it. since its used anyways it cant hurt to take the back off and see and study how it works and how the drums suspension works. you can try to find the springs at an appliance store. Im not sure if you can get springs directly from LG. LG's are a pretty good name brand, probably worth fixing..
good luck!
Dec 28, 2009 | LG WM-2277HW Front Load Washer
Comes up with the sign UE ??
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Sep 09, 2009 | LG WM-2277HW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
LG Washing Machine stops spinning in mid cycle
• Water supply is not adequate in
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
Apr 27, 2009 | LG WM2487H Front Load Washer
UE error code
You may have a problem with the ball balance sensor.  One of the things I have noticed is when the installers deliver and set up the washers, they get a little too rough and cause a dent in the rear panel of the washer.  In the rear panel, the ball balance sensor is mounted onto the frame.  If the tub spins too wildly, it will hit the ball balance sensor causing it to go UE.  But if the back panel is pushed in too much, the tub will actually make contact with the ball balance sensor too early causing a UE error code.  You will need to have a qualified LG technician look into it.
May 07, 2008 | LG WM-2277HW Front Load Washer
LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
LG WM-2277HW Front Load Washer Logo
352 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
