Question about Brother HL-2040 Laser Printer
Light printing We replaced the toner cartridge and still keep getting light copies. Is the drum worn out?
    Scholar:
  • 94 Answers
The drum shouldn't be "worn out" but the mirror from the laser may have become dirty from the toner dust give ther printer a good clean out and clean the silver reflective stripe and all should be ok
Posted on Aug 01, 2010
Black line scan
Sir
Checking the print cartridge
Image formation defects are many times the result of print cartridge problems. If there is any doubt, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Or Go To Below Link To Find all The HP Printer Help For Your HP Printer Problems
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-bpl70340-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1390257139382.876444892.492883150
In Case You Need Help Then Follow Us On:
HP Printer Support
Jan 20, 2014 | HP LaserJet 1100a Printer
Printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
My hp laserjet m1005mfp printer is not printing document while i replace its cartridge twicely so give me solution urgently
Image-formation defects are frequently the result of problems in the print cartridge. If the source of the defect is not immediately evident, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to make sure that the print cartridge is still operable.
? Make sure that the print cartridge is seated properly.
? Check the print cartridge to see if it has been disassembled or refilled.
? Inspect the print cartridge to see if toner is leaking through worn seals.
? Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or
and image defects.
? Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been
To redistribute the toner in the print cartridge
Before installing a new print cartridge or when the toner begins to run low, redistribute the toner by
Jul 22, 2011 | HP LaserJet M1005 Printer
My laserjet printer started making load noises and no longer prints-the last thing printed only printed the top 3inches and then was all black, it then stopped working altogether
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- raaj_k001@rediffmail.com
Jan 12, 2011 | HP LaserJet 1200 Printer
I own a Sharp Al-1655CS about 2 yrs old, I have a problem, the balck toner powder is exiting the back of the machine and copies are very light. The copy count shows 12,000 copies made. I have repalced the...
These are very good machines so I would see no reason to replace it. Do you have the operators manual? If so look up the setting for "toner save mode" and make sure it is NOT turned on.
The drum unit is good for at least 18,000 pages so I would not suspect the drum. I even reset the counters on the drum units and can get up to 36,000 pages on them. Do you have the machine hooked to a PC for printing? If so is there any difference between printer density and copy density? If so then the issue is with the scanner density setting. If the copy and prints are both light then it is a print engine problem. If several toner cartridges are doing the same light print then I would suspect that your laser scanner optics are dirty. There is a narrow strip or slot just above the drum unit that the laser beam goes thru to write the image onto the drum. This should be cleaned and then the machine re-tested. If no improvement is see then the machine will have to be dis-assembled and cleaned which would require a compentant service technician.
Good Luck and Thank You for using Fixya.
Aug 14, 2010 | Sharp AL-1655CS Laser Printer
Streaking on left side of page
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
I have a Ricoh 3900L and It prints very light and streaks in the center of the page I have cleaned it and my add toner light is not on. I faxes out fine it is the incoming faxes and copies that are bad.
It sounds like you probably need to replace your toner cartridge. The add toner light is not on because you still have toner in the cartridge, but some other part of the cartridge has likely gone bad (such as the developer or the drum). Replacing the toner cartridge should take care of your copy quality problem.
Hope that helps!
Dec 19, 2009 | HHP FIXED MOUNT LINEAR (3900lx-12)
Poor quality copies
Hi, this is most likely caused by a worn or faulty drum.
Jan 20, 2009 | Sharp AL 1631 Copier
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother HL-2040 Laser Printer Logo
240 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
