Question about HP Officejet 5610 All-In-One InkJet Printer
Cant delete printing job
I tried to cancel a printing job and all it says is deleting and i cant print anything else
    Master:
  • 497 Answers
Try Ctrl Alt Delete to end it from the task manager. Then restart your computer.
Posted on Aug 01, 2010
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
I was printing a job and had reworked the document and wanted to print it again, but, all of a sudden, the printer does not print or copy anything. All the cables are securely fastened. I have plenty of...
unfortunately, you have to delete the print queue, then delete the printer (including copies of it if there's any). unplug / reconnect usb cable
Apr 04, 2008 | SATO M-8450 Printer
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
I have try to delete a printing job and it will not print and will not allow anything to be print. However, I was able to delete the other jobs after the first job but the first job willnot delete
Sometimes if the printer cable is unplugged it will reset. Try that. Also the printer menu should include cancel print jobs. Is that cleared? I would also turn off computer for a moment, and turn back on. Thqat may clear the print job.....
Apr 19, 2014 | HP Photosmart C4100
Can't delete print jobs
If you are using a Windows platform then if you look at the bottom right of the screen you will see a printer icon. Double click on the icon and the print queue will be displayed. To cancel a print j0ob, highlight the job and then cancel it.
Don
Nov 18, 2009 | Dell 968 All-In-One Printer
Printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Jan 25, 2009 | HP PSC 1410v All-in-One Printer
Printer Queue blocked by 'Deleting' problem
THere is an easier solution.
Restart the printer spooler service. THis solves problems very often
Jan 21, 2009 | Samsung CLP 300 Laser Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Not printing and nothing is paused or on the print list.
First of all you must let canceled print jobs finish deleting before sending new jobs, if the job is taking too long try restarting the computer with the printer on to clear the jobs this usually works if not then after restart open the printers folder and cancel all jobs here. let them finish deleting while the printer is still on (they must remain in communication during deleting jobs. Once all jobs are gone, remove the power brick from the printer for about a minute then reinsert and let the printer start up if it doesn't after a minute or so just turn it on once it finishes then try printing again.
Oct 14, 2008 | Dell 926 All-In-One InkJet Printer
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
171 people viewed this question
Seeker5211
Seeker5211
