UE is showing up on the screen part way through the wash cycle do you know what this stands for please?
  • julie&james Aug 01, 2010
    I have turned off at the wall for 20mins then will restart if this does not work I will get someone in to fix it.
    Thanks for your help it was much appreciated.
  • 15,935 Answers
UE stands for Unbalanced error.
In order for this error to show - it must be tripped 3 times.
re-distribute the load.
If this error continues - no matter the load - the support shocks may be worn or snapped.
Unplug the washer for 20 minutes to clear the code, and re-try.
Thanks!!
Posted on Aug 01, 2010
How to solve issue my samsung washing machine model WF602W2BDBDQW SHOWING ERROR ue
The UE error mean unbalanced error. Check the link below to find how can you fix it http://www.samsung.com/uk/support/home-appliances/my-samsung-washing-machine-is-showing-a-ue-code-during-a-spin-cycle-what-can-i-do/
All the best !
Apr 29, 2018 | Samsung Washing Machines
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
How do I rectify the UE code , I have finoished my wash but it is still showing up
Hi.
US means unbalanced error. Try balancing the unit as explained on the owners manual. Try redistributing the load. Check the floor. If that does not work try following the instructions in the diagrams for the specific code available on the LG support website. Here the link.
Regards.
Ginko
Sep 06, 2011 | LG WM-2077C Front Load Washer
Sometimes on the wash cycle the machine stops and the lettering ue appears on screen and flashes
Two possible problems too much weight (pieces of clothing) and second you need to redistribute the load to make it even, and re-engage the wash cycle again. Good Luck
Jan 06, 2011 | Washing Machines
UE displayed on panel westinghouse 708 washing machine near end of cycle shows 6 mins left on spin then shows UE, cannot go into normal cycle.
I WOULD TRY TO LOOK AT THE DRAIN PUMP ASSEMBLY ON THE UNIT.... IT IS EITHER STOPPED UP OR NOT PUMPING FAST ENOUGH OUT DUE TO DEBRI IN THE PUMP AREA... GAIN ACCESS TO THE DRAIN PUMP AREA AND REMOVE HOSES AND LOOK INSIDE AREA.
the code data base for this is saying ue = drain failure... hope this helps you out
Jan 06, 2011 | Westinghouse Washing Machines
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
