Question about Dryers
Kleenmaid speed queen dryer running , but no heat comming from machine. Plenty of gas in tank, have taken front plate off , no pilot light or flame when going. System has a automatic electric pilot and main gas line.
    President:
  • 1,554 Answers
You should check igniter first when the dryer is started. It should glow red hot to ignite the gas. The issue is with the gas valve coils if the igniter glows red hot but no gas is ignited; replace both coils. On the other hand if the igniter fails to glow red hot, check the continuity of the thermal fuse and/or cycling thermostat on the blower housing and the high-limit thermostat on the burner assembly. You can bypass all of them then start the dryer. The burner should fire up then stop the dryer and un-bypass each of them one a time then restart the dryer. In this manner, you will be able to find the culprit. Replace it and the dryer should start firing up and working properly. Do not use the dryer with the previously mentioned components permanently bypassed to avoid fire hazards.
Indicate the exact model number of the dryer should you need further assistance. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated
Posted on Aug 01, 2010
  • 4 more comments
  • forestedgerc Aug 01, 2010
    hi Jahn,
    I have checked the igniter and it isn't glowing red at all.
    The model of the machine is LGK37AWF3058, serial number 0105001912.
    Where do I find the thermal fuse ,cycling thermostat and high limit thermostat, and how do I check for continuity. Also how can I bypass them to test which function isn't working
  • Jahn27
    Jahn27 Aug 01, 2010
    The thermal fuse and the cycling thermostat are both located on the blower housing while the high-limit thermostat is mounted on the burner tube.
    You will need a multimeter to test the components for continuity but if you don't have one, bypassing the components will do. Simply jump a wire between the terminals of each component to bypass them or simply connect the wires. Once done and the dryer works, un-bypass them one at a time to determine the culprit. The un-bypassed component is the culprit if the dryer stopped working. Do not use the dryer with
    the components permanently bypassed to avoid fire
    hazards. You should replace first the failed component.
    did you recieve my previous email regading questions and model number to the original enquiry
  • Jahn27
    Jahn27 Aug 01, 2010
    Yes..
    Yes , sorry I didn't see your reply.
    Have isolated the problem to the two sensors just above the flame in the burner tube. One is working fine , but the lower one with a pin in the centre of it is the cause of the dryer not working.
    I presume this is the high limit thermostat and it is designed to stop the gas flow if the blower was to stop so the flame doesn't continue. If this is corect is it best to take a side panel off the remove it or just approach it from the front of the machine . What is the part number and discription for ordering.
    If I run the machine in the short term is it okay as long as I am in constant check that the blower is going ?
  • Jahn27
    Jahn27 Aug 01, 2010
    Those two components wired in series with the gas valve coils and indeed designed to stop the gas flow by cutting power to the coils closing the valves. The apparently working one is the high-limit thermostat and the blown one is the thermal cut-off which fails when the former fails to cycle on and off. Both parts must be replaced; otherwise,you will have the new part blow again soon. Just approach them from the front of the machine.
    You should not run the dryer with any safety part bypassed. The dryer will continuously heat up with that part bypassed and eventually result in the burning down of your clothes. You can order the parts here. The site is out-of-service right now but will be back soon. Just enter the exact model number of your machine or chat with them. Give the model number and tell them the part you need, thermal cut-off and high-limit thermostat.
Ignitor works, lights the gas, then when the ignitor goes off, so does the flame.
Hi Stanley,
the problem with the dryer flame going out is caused by defective coils on the gas valve and the gas valve coils should be replaced
Dec 03, 2011 | Speed Queen Dryers
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
My gas water heater pilot light will not stay lit
Hi Mike,
1stly you have to understand what the pilot light does!
Yes, it lights the flame, but it protects you from gassing yourself!
that is thye main job!
hava a look inside!
In front of the pilot flame, (it might have a double flame... (one flame on the bottom & another on top.) is a curved piece of metal plate. The flame is supposed to heat that plate untill it it very hot! Thenm the plate bends down as it is a bimetyaalivc strip!
This opens the bsaety valve & you can let go.
The flame will noe stay on. If a gush of wind blows the flame out, the strip will cool & the safety valve close, preventing a dead family in the morning.
There is a newer system as well.
Right in front of the flame, is a pointed sensor with it's tip in the flame. . It has a electric cable running to a safety valve. This sensor have to heat up as well. It is a heat battery that activates the valve. See that it did not move!
If it heats up, & the valve does not keep the pilot flame going after a few seconds, the unit has to be replaced!
Safety first!
Andy
Sep 04, 2011 | Water Heaters
The pilot ignitor lights up but gas doesn't light off
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 25, 2011 | Speed Queen AGS28AWF Gas Dryer
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Jul 23, 2008 | Dryers
Dryers Logo
119 people viewed this question
Top Dryers Experts
Marvin
Marvin
