Question about Humminbird 7100021 Transducer, Shs 7w
Humminbird TCR ID 1 Transcucer/ Sensor
Do you know which I need to purchase? Looking at all the options I'm confused. The unit is supposed to be 455 Khz and I can't seem to locate the right product or maybe I'm just not looking for the right item. Mine has gone bad on my boat and I need to get a replacement Transducer/ Sensor. Thanks Jeff
3 Suggested Answers
  • 29 Answers
SOURCE: I have my Humminbird fishfinder
I would contact our customer service group and they will be able to help you. Our number is 800-633-1468.
Posted on Jan 11, 2011
joeguest2
  • 2080 Answers
SOURCE: what frequency transducer does the humminbird
That unit uses a 16 degree - 200 KHz transducer.
Found the info in a forum at the following site:
http://www.icefishingmichigan.com/forum/showthread.php?t=233551
Hope that helps.
Posted on Mar 20, 2011
Magic color 7450 error code 36 density low k...how can this be solve
Abnormally low toner density detected Black TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 4 % or less for a given number of times consecutively.
1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty.
3 M7 operation check PWB-M CNDM3-10 to 13 C-23.
4 Reinstall Imaging Unit.
5 Change Imaging Unit /K.
6 Change PWB-M.
7 Change PWB-P.
Feb 06, 2016 | Office Equipment & Supplies
How to solve trouble code c 2553 in konica Minolta c 451
Code C2553 Description Abnormally low toner density detected magenta TCR sensor
• When sampling data is determined in TC ratio calculation control, TCR sensor output is higher than a predetermined value for a predetermined number of times in a row even though there is toner in the sub hopper. Remedy 1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR sensor window on the underside of the imaging unit if dirty 3 Reinstall imaging unit. 4 Reinstall toner cartridge. 5 M9, M10, M11 operation check (At this time, IU must be non-installation.) M9: PRCB CN16PRCB-1 to 4 M10: PRCB CN16PRCB-5 to 8 M11: PRCB CN16PRCB-9 to 12 C-22 to 23. 6 M13, M14 operation check M13: PRCB CN17PRCB-5 to 8 M14: PRCB CN17PRCB-9 to 12 K-1. 7 If the toner empty sensor and its surroundings inside the sub hopper are dirtied with toner, clean them. 8 Change imaging unit. 9 Change PRCB. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C451
May 21, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
Code eror bizhub c252
Code: C2557 Code C2557 Description Abnormally low toner density detected Black TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 5 % or less for a given number of times consecutively. Remedy 1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty 3 M7 operation check PWB-M CNDM3-10 to 13 C-21 4 Reinstall Imaging Unit. 5 Change Imaging Unit /K. 6 Change PWB-M. 7 Change PWB-MFP.
Feb 01, 2015 | Office Equipment & Supplies
Looking for swivel mounting bracket for a humminbird lcr 4 id
They are on EBAY....
http://www.ebay.com/itm/Humminbird-Mounting-System-Cover-MC-W-740036-1-MC-W-700-798-788-778-/140948056331?pt=LH_DefaultDomain_0&hash=item20d128a90b
Apr 08, 2013 | Humminbird Fishfinder, Piranhamax 210 Pt...
How to fix error c0f32 in konica minolta bizhub 180
Faulty TCR Sensor
• The measurement taken by the TCR sensor (TSRS) at a
time 2.0 sec. after the main motor (M1) has started turning
is less than 5% (greater than 4.63 V).
• The measurement taken by the TCR sensor (TCRS) at a
is 19% or more (1.41 V or less).
I would start with checking the TCR sensor located on the developing unit. Make sure it isn't caked up with toner. After that I would replace the developer and then the sensor. Check the developer unit for any damage to gears and seals.
May 14, 2010 | Konica Minolta bizhub 180 All-In-One...
Need the directions to wiring the humminbird fish finder piranha max 210
Wiring should be very straightforward, the connector on the left (looking at the back of the sounder) is the plug for the transducer, the 2 pin plug in the middle is for the power (notch in the plug cord points UP), and the 4 pin connector is for the optional speed and/or temperature sensor. Here is an install manual for your reference:
http://www.humminbird.com/PDF/Piranha1_2_IN.pdf
Mar 15, 2009 | Humminbird Fishfinder, Piranhamax 210 Pt...
Humminbird 7100021 Transducer, Shs 7w Logo
362 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
