Question about Hit Thomas the Tank Engine Morgan's Mine Railway Set
I have a Take Along Morgan's Mine playset, and it is missing one piece of orange track. How can I get a replacement piece?
Looking for any spares from TOMY Thomas Post Office Loader, piece L and M and percy if anyone has an incomplete set they want to sell?
HiI've just bought my son a set which is also incomplete (a single piece of track missing - how annoying!) Happy to sell you the whole lot for a fiver plus postage if you're interested. It's in lovely condition.
Mary
Jan 27, 2013 | Samson Technology Thomas Trackmaster Zip...
Elevator won't go up and down, I have solved this now but don't know how 2 put the elements together 2 make it work
It looks like you are missing a piece that connects the elevator base to the track that it slides on.
Jan 05, 2013 | Toys
I inherited a thomas and friends coal mine set. i need owner's manual to see if i have all the pieces and its set-up
the set you're talking about is called the tomy thomas big loader set you can probably find the instructions off google images
Aug 17, 2012 | Tomy Thomas The Tank and Friends Track
Need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
I have a new bright animated holiday train from a garage sale and I think I am missing a power cord
You should have a 3 pieces to provide power....
1. A track connector box. Looks like a "T". It slips under the track to make the track power connection. The transformer plugs into it (2 pin Molex type connector) and the command console (has an RJ11 telephone jack type connector on it)
2. A large square transformer. One end plugs into the wall and the other into the track connetor box.
3. The Command Console. Has the on/off button, forward, reverse, mute, sounds and speed contol on it .. has a connector that looks like a telephone plug.
Unfortunately... DO NOT look to New Bright for missing or non working parts. New Bright does not offer repair or replacement parts for thier products. :-( ....
Dec 10, 2009 | New Bright 384 Holiday Express Animated...
Need instructions for thomas and morgans mine
need track layout for thomas morgan's mine
Oct 19, 2009 | Thomas The Tank Toys
Buzz & friends pixar train track isnt complete
121 W 27th St
New York, NY 10001-6207
you may have to write a physical letter if you research online it says that the company has filed bankruptcy i tried all the numbers on all the boxes that i could find in my house made by them and none of them work hope i helped good luck. :)
Mar 30, 2009 | Planet Toys Disney Pixar Buzz and Friends...
Little Tikes Swing Along Castle
Your 4 screws may hold the swing piece to the slide piece. You actually secure it to the slide side wall with one of the red screw caps but you can also secure it with 4 screws that screw into the plastic.  You can also find the manual and assembly instructions at littletikes.com
Mar 04, 2009 | Little Tikes Swing Along Castle
Antenna missing
Mine came off several times along with the plastic housing. I glued it back in place with 5 minute epoxy. Make sure the metal contacts engage properly and that your signal strength is at it's highest level before you apply the glue. Mines been going 3 years since glued
Jan 04, 2009 | Cell Phones
Hit Thomas the Tank Engine Morgan's Mine Railway Set Logo
189 people viewed this question
Top Hit Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Hit Toy Expert? Answer questions, earn points and help others
