How do I fill the epson stylus c90 black ink cartridge? What is the location for the drill hole? How many mLs of fluid can I inject? The cartridge number is TO731. We bought the Jet Tec refill kit, it displays dozens of refill instructions for other printer models but not the epson stylus c90. Thankyou very much for your time, and I look forward to hearing from you. Kind regards, Terry Hoy, Coffs Harbour
    Genius:
  • 1,447 Answers
Check this site and download the pdf file
http://www.ziddu.com/download.php?uid=Z6qbm5SpZqyZlOKnZaqhkZSnYqufmpSu5
or visit this site
http://www.castleink.com/_a-pri-ref.html
Hope this helps
Posted on Apr 25, 2008
I need to know how to refill my ink for my nx110 printer
The ink cartridges used in Epson's Stylus line of printers are very similar to the ones used in its other printers. A handful of cartridges--like the S020034, S020047 or S020049--may require a slightly different refilling technique, but they all basically entail opening a fill hole in the top to run down into the ink chamber within. Once the chamber is accessible, you can use a basic refill kit with a syringe bottle to refill the chamber, as with most printer-ink cartridges.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
1. Hold the cartridge upside down so the outlet holes to the printer paper are on top. Cover each hole with a piece of tape, then turn the cartridge right-side up.
2. Make a hole in the top of the cartridge above each ink chamber. For most cartridges, simply poke a hole through the label with a toothpick. With cartridges like the Epson Stylus 34 (the casing of which is black), pull back the label to reveal the filling holes and puncture the seal of each home. For the 47 or 49 color cartridge, drill a 1/8-inch hole in the shell between the label and front edge.
3. Determine which color of ink is in which chamber (if you're refilling a color cartridge). The toothpick used to puncture the hole should draw out some ink to show you. If you have a cartridge in which you punctured the label directly, the order of the color chambers is usually cyan, magenta and yellow. If you created the hole in another way (like with the 34, 47 or 49 cartridges), the order is usually magenta, cyan and yellow.
4.Fill the syringe bottle with 5ml of ink. Insert the needle in the filling hole and inject the ink. There may be a sponge inside the chamber, so make sure the needle goes all the way through to the bottom. The 34 cartridge takes up to 12ml of ink.
5. Tape over the fill holes you created. If you drilled the holes, plastic plugs (like the ones included in a refill kit) can work as well. Leave the tape on the outlet holes as you replace the cartridge in the Epson Stylus printer.
6.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Tip
How to Refill the Epson R340's Ink Cartridge
<span>Instructional steps<br /></span> Things You'll Need: <ul> <li> <span>Syringes</span> </li> <li> <span>Refill ink</span> </li> <li> <span>1/16 inch thumb screw</span> </li> <li> <span>Paper towels</span> </li></ul> <ol> <li> Place the cartridge on a flat surface over some paper towels to soak up any spilled ink.<br /></li> <li>Drill a hole directly above the "H" in the word "Push" on the top label.<br /> </li> <li> Drill a hole above the the first hole so air can escape while you are filling the cartridge.<br /> </li> <li> Fill a syringe with the correct color and amount of refill ink. The black cartridge holds 25 ml of ink. Color cartridges hold 10 ml of ink.<br /> </li> <li> Insert the needle of the syringe into the first drilled hole. Slowly inject the ink into the cartridge.<br /> </li> <li> Replace the cartridge into the Epson R340. Allow it to rest for 24 hours so the ink can absorb into the sponge inside the cartridge.please rate this post by saying how helpful it is to you<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_7414161_refill-epson-r340_s-ink-cartridge.html#ixzz13r3MVnYc"><br /></a></span>
on Oct 30, 2010 | Office Equipment & Supplies
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
Don't know exactly where to drill a hole to refill Epsom T0711 printer ink cartridge. Can you help?
Thanks for using Fixya.
You won't need to drill hole anywhere.
Visit this link to get all the instructions required to refill the ink in Epson T0711 cartridge.
But remember you would need a chip resetter gun to re set the chips on the ink cartridges after you refill the cartridges.
Visit this link to buy Universal chip reseter if you don' t have.
Good luck and have a nice day.
Jul 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Can I refill the ink in my Epson Tx110 stylus printer ? I have the ink but have no instructions as to where to make hole in black and color cartridges. Please HELP Thanks
You should be able to refill the cartridges with no problem I do it all the time on a variety of different printers, I'm not familiar with that particular model, I am guessing that you are in Australia, here is a quote from their page for your printer:
"This printer is designed to be used only with Genuine Epson Intellidge™ ink cartridges
Intellidge™ Ink cartridges are not designed for refill."
So I am really not sure hope that has been some help.
If this helps, with the Epson C40 Stylus here in Canada there is only two cartridges black and one for the the colors if you rub your over the sticker if there is one towards the back of the cartridge it should show an indentation this is on the C40 cartridges, this is where you fill the cartridge, same on the black I believe, that or may not work for you.
Apr 06, 2010 | Epson Office Equipment & Supplies
Want to refill ink cartridge but don't know where to inject ink.
Check this out:
www.disc-info.com/downloads/jr-refill/epson/jr-epson-t0711.pdf
Feb 25, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I put ink cartridges in the printer but there is no attempt to print on the page. Printer acts like its printing; no ink shows.
You have to buy ink fill (online,ebay.), then you have to carefully insert the injection through the 3 holes ( peel off sticker,CAREFULLY!). Hoped this helped!
Jan 26, 2010 | Epson Stylus 2200 InkJet Photo Printer
How to refill an ink cartridge
Buy a refill kit , inside is a small drill to make a hole in the top of the current cartridge and a syringe to inject the new ink.
There will also be a diaghram of where to drill
If it is black only then I got a nurse pal of mine to get me a 20ml Syringe and a couple of needles.
I then pumped the ink directly into the breather hole in the top of the cartridge (It is under the label
It is a messy process so have some sheets of paper down when you do it and also some surgical gloves help keep the ink off your fingers.
I
Jul 09, 2009 | Epson Office Equipment & Supplies
Swap black inks with Epson 9800
By using Colorbyte's Imageprint software and their 'Phatte Black' cartridge....
www.colorbyte.com
I have not purchased it myself quite yet but im good friends with an Epson R&D guy who tested their system and highly recommends it.
Mar 20, 2008 | Epson Stylus Pro 9800 InkJet Printer
167 people viewed this question
k24674
jasbo
jasbo
