Question about Abit NF8-V Motherboard
I have a home built computer that uses an Abit NF8-v mother board, I am not sure how,but it started when it dumped my D-drive and a few other things. So I went in to the bios and reset it the configurations to default, and I also messed with the Cache setting, it worked fine for an hour or so, then it started beeping. I lost the connection to my monitor, keyboard, and mouse. I was finally able to get to stop beeping, but I still do not have power to my keyboard, mouse or monitor. The cpu fan works, the led light works, my disc drives/ cd drives work, my power supply is fine. I do not know what to do now...please help me. I have tried unplugging the main power supply, the memmory, the jumpers, the video cards and I took out the floppy disc drive. Please help me... Thank you
  • 4,924 Answers
JUst try to remove the Bios battery ..and before you insert it again ..be sure that you connect all the things back like they supposed to be ...Removing the bios battery will reset it to the factory optimal default ..so the first thing you will have to do after inserting it back ...is to power it ..and it will prompt you to go to bios and set the time and data...But ..my suggestion is just to press F1 or whatever will ask ..go to bios and do not mess with anything ...Just press F10 to confirm your choice ..and after you are in Bios ..set the time and the date ...Another issue if you have 2 Ram memories..and at one point it beeped long ...and now it is only making a looping (repeated) click noise ...it means that one of your Ram memories is not either inserted right ..or is gone ...
Also take a look to see if all the screws from the motherboard are in place ..cause sometimes if they are not all screwed ..the motherboard is slightly bending in the vertical position ..and causes Ram memory mis-contact
Posted on Aug 01, 2010
  • 6 more comments
  • elisha mcn Aug 01, 2010
    when I remove the bios battery, do I need to turn off all of the power supply?
  • Catalin Turcu
    Catalin Turcu Aug 01, 2010
    yes turn the power suply off from the button ...or remove the cable ...the removing of the battery will have the same effect like resetting the bios to the factory ..to the original including the date it was manufactured..so ..any strange setting you might have made will be back to normal in bios and also the devices will be force recognized again ...
  • Catalin Turcu
    by the way ...Like I said ..if you have more than one ram memory unit inside...try them one by one after doint the battery thing ..cause if one of them is damaged..(this may explain the stopping after a while ) this will also cause it not to power like it should but only working the fans and making a click noise.. ...and if the Ram is damaged the chance is that not all of them to be gone ..and this way you will identify which one is causing the problem ..
    In the end..if still not working ..check the cooler from the CPU to not have any movements and be secured in place ..this cause also boot failing ..cause the temperature maximum limit is reached too soon if teh cooler is not fixed on the cpu so that the heat dispenser to work ....all this time you can keep it open and on the side so that you can watch all the coolers ..and be able to work and remove things one by one ...
    for the first I will try to boot to bios without the hdd so to avoid any windows related things ...If it boots to windows than you know that the motherboard is OK ..and you get to the next level when you concentrate to the HDD and the operating system ...
    I did everything that you said, I removed the bios battery and then put it back together, turned on the power supply, and nothing changed. it beeps now, and the monitor, keyboard and the mouse still are not functional. Do you have any other suggestions?
  • Catalin Turcu
    if it beeps ..than is the Ram memory to blame ...like I said ...if you have another ram memory available ..just remove the one you have inside..and put the other one ...If you have 2 into the computer ..remove them one by one ..and try t boot the computer with only one inside..if it does the same ..with only one ...at least you eliminate the possibility that something is wrong with the ram memory ..The idea is that only if it is from the ram memory makes this kinda noises or click ..and do not start ...The ram memory is the first detected on boot and not even the BIOS settings are not diplayed if the ram is not working ....
    Good afternoon, so this is were I am at, I checked the ram and they are in perfect working condition, I took out the bios battery, the cmos battery, I took apart the heatsink fan and cleaned ( it was filthy), and the leadtek graphic card ( it too was filthy), I made sure to connect everything back the way it was supposed to be, I did cross cancellation on the fans, the drivers, the floppy disk, the power supply and the leadtek graphic card. My computer is still beeping. But when I take out the leadtek it stops beeping, but then if I do that, I do not have a port to connect the monitor....any suggestions? I am determined to get my baby back on line, she's all I got. Please help
    thank you very much for your help, I totally appreciate it. I finally got my computer to work. Thank you thank you
  • Catalin Turcu
    If you got it to work ..and you didn't realized exactly what it was....sometimes it is just a loose contact or need cleaning in essential points like the CPU fan ...always take it one by one ..and it will do ..or at least you step on the issue sooner or later ..Have a great day ..
I have installed my abit nf8-v2 motherboard into my computer but i can not get my computer to power on. LED 2 is turning on but not LED1
Please verify that you have completed the following:
  1. Connected the cables from power supply to the motherboard
  2. Connected the processor fan power connector
  3. Installed the memory correctly
  4. Connected IDE/Sata cables correctly
  5. Processor installed correctly with fan sitting correctly
Feb 08, 2011 | Abit NF8-V2 ATX Motherboard with NVIDIA...
Few minute ago when i tried tunring on my pc it just stayed at the abit-intel loading screen thingy. (im entirely new too pcs fixing them that is ) it too about an hour or so befor it would tunr on normaly...
It could be the hard drive or any usb devices plugged in when booting up the computer. Try unplugging the hard drive and remove any USB devices and then try turning on the PC.
Dec 06, 2017 | Abit AB9 Pro Motherboard
I have an Abit NF8 series motherboard and am using a amd 3200 --- I am wondering if I can but in a bigger processor as I am running 2.2 ghz and I need 2.6 for a game I would like to play. Is it...
You can put in bigger processor, Any AMD Athlon or Sempron will do.
If you are planning to run big games, then I suggest you get
- A new motherboard with PCI Express 2.0 support
- A new processor
- A new graphics card (maybe 512 MB or 1 GB) with DirectX 11 hardware support and Shader Model 5
You may make that DirectX 10 or 10.1 and Shader 4 if you want to reduce cost.
Aug 13, 2010 | Abit NF8-V Motherboard
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
I have just built my own computer tower with a abit va10 mother board,which i have just installed.The problem is i need a manaul for a ABIT VA1O A SOCKET 462 PIN MOTHER BOARD to set the board to the...
Here is a web page with direct links to download the manual for this motherboard:
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=VA-10&pSOCKET_TYPE=Socket%20A
Sep 02, 2009 | Abit VA-10 333MHz FSB VIA VT8378 Chipset...
No audio on custom built computer using Abit NF8V
I'm assuming you have the little jacks for the speakers to plug into.... As crazy as this sounds, make sure you have the speakers plugged into the right jack. The icons by the jacks are not all that clear. You might have the speakers plugged into the "Line In" jack? I've done it myself and I'm a Computer Engineer!
Aug 09, 2009 | Abit NF8 Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Usb pen drive
get any and all updates pertaining to the mother board. some generic USB devices wont pick up because they are bassically made without proper firmware built in so your PC cant recognize what type of device it is. I would go with Lexar, ther like $20 for a gig at wallmart
Feb 15, 2008 | Computers & Internet
Abit NF8-V Motherboard Logo
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
