Question about Nintendo Wii Console
Wii console won't turn on after a power surge. Had it plugged into a surge protector. Is there a reset button?
    President:
  • 1,382 Answers
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Posted on Aug 01, 2010
I had a power surge about a month ago and now my wii will not turn on. My wii is pluged into a surge protector.
I posted this elsewhere on here too, but I'll post it here too so it helps you.
This is a common problem with the Wii. You wouldn't believe how often I read about this. I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Wii went dead after power surge
Please visit the site HERE it.You will find a solution to your problem.
I would also suggest holding the power button on the Wii Remote itself to turn it on, or unplug your Wii Console's power cable and audio/video cable for 90 seconds. Then plug power in first, then AV cable.
Goolduck..
Feb 23, 2008 | Nintendo Wii Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
I cannot get the power to wii console.all connections are ok
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 03, 2009 | Nintendo Wii Console
Wii work for 3 weeks will not turn on .
There is no light on the front, correct? No red, yellow or green?
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 30, 2009 | Nintendo Wii Console
My wii will not turn on, I have never had a problem with it before. I checked all of the plugs and everything seems great except it will not turn on.
It seems every 5th problem I see is this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii or in the Owner's Manual.
Power will come back on, or you'll go to turn the Wii on one day, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 29, 2009 | Nintendo Wii Console
Trying to change fuse in wii but need to know where to find it
Is your Wii just not turning on, no indicator lights? No red, yellow, or green, and pressing buttons doesn't work? Try re-setting the AC adapter.
Nov 21, 2009 | Nintendo Wii Console
The power button...console will not turn on. No
I see this issue on every site and Wii forum I visit. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
Nov 16, 2009 | Nintendo Wii Console
No Power/ No light
You need to reset the AC adapter (I'll explain below)
Nov 14, 2009 | Nintendo Wii Console
My wii won't turn on
You likely had a power failure. You need to reset your AC adapter. Here's how:
  1. unplug the power cord from the wii. Unplug the adapter from your surge protector or the power outlet.
  2. wait 90 to 120 seconds. (Some people say to wait 30 seconds. Wrong! At least 90 secs is required for the AC adapter to rest.
  3. plug stuff back in and you're good to go.
NOTE: electronics like your wii, ps3, etc should be protected from power surges and power failures! Plug them into a good surge protector. Always!
Jun 27, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
652 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
